Results 1 to 10 of 16
Thread: xenarc problem - think i fried it
    Feb 2005
    Unhappy xenarc problem - think i fried it
    Go easy on Teh N00b i did a search but came up blank on the matter...
    i have a 700TSV and for the last few days I would power it up and it would run fine for five minutes tops and then any image on the screen would stop moving and the entire image would fade to bright white. immediately i would power the computer down and the image would flicker at the windows XP shut down screen but still be very hazy and bright white. i am running onboard Epia video so even with PowerStrip i cannot run the native resolution of the screen. before i installed PowerStrip the image would shift to the right and leave a blank black bar from time to time. i would change the resolution and all would be well. I installed PowerStrip about two weeks ago and the image was fine at 800x600. now all i have is a white haze a few minutes into operation any thoughts or input are welcome as to what i may have fried
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Try different refresh rates like 70, 72 or 75Hz.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    Feb 2005
    Quote Originally Posted by strohmrs
    in the preferences > settings screen, right?
    Dec 2003
    Surrey, BC, Canada
    display properties > settings > advanced > monitor > select from the dropdown list of refresh rates
    Jun 2004
    Idaho
    Quote Originally Posted by Bobby Digital
    Yeah, try it there first before messing around with PowerStrip.
    Rick S.
    Feb 2005
    i've already got powerstrip enabled. would you suggest disabling it or uninstalling it?
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by Ken's SA22c
    Probably a good idea untill you get the main problem fixed. It sounds like a "out of range" problem though. Too high of a resolution or refresh rate.
    Jun 2004
    Idaho
    Disable PowerStrip for the time being or at least set it for standard default resolutions and timings until you narrow it down.
    Rick S.
    Jul 2004
    I had something similar happen to me on the Starvision monitor I own. It turned out that the plastic ribbon cable between the controller and the panel was damaged and some of the traces were broken. This was also was when I discovered that my new starvision monitor was not so new after all.
    Anyhow, I figured this out by opening the monitor up and moving the cable around a bit while the monitor is on. If the cable is damaged you may be able to buy a new one. In my case Digitalww had them in stock for $6. Remember that opening up the case may void your warrenty.
    Feb 2005
    Quote Originally Posted by momanz
    the case is already mutilated, fiberglassed and bondoed into the dash so warranty is long gone
    the refresh rate with powerstrip uninstalled was set at 60hz. i set it to 75hz and drove around with it for a few hours and all was well...
  1. problem with 800x600 with xenarc 7"
    By shiltz in forum LCD/Display
    Last Post: 02-13-2005, 02:09 AM
  2. Problem with Xenarc TS
    By bluehcc in forum LCD/Display
    Last Post: 01-19-2005, 01:13 AM
  3. xenarc 700tsv problem
    By dannn in forum LCD/Display
    Last Post: 12-31-2004, 02:34 PM
  4. Blurry Xenarc Problem
    By Lord_Pall in forum LCD/Display
    Last Post: 12-24-2004, 09:26 PM
  5. Xenarc 700YV Problem
    By Sivion in forum LCD/Display
    Last Post: 12-04-2004, 06:46 PM
