If your going to be justing running the xbox on the screen then you don't need the vga screen.
Hello all, although I am only planning on installing an xbox in my vehicle I was hoping you could help me in regards to choosing a monitor. I know the lilliput and xenarc vga monitors with vga input are considered essential for a carputer due to the small text, but do you think it is also needed for an xbox which is only capable of rca video output? There are boxes which convert rca to vga signal but I dont think it is true vga output. Or should I save some money and just get a xenarc with no vga input?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
If you're going to be running linux and be able to read the text on it, then the X2VGA will work well for you. If you're only going to be playing games, then it probably won't matter what you do.
I have one and it works very well. The X2VGA doesn't require a seperate power source either. Only thing you have to remember is that you'll need to turn on the hi-def mode on your Xbox (in the MS Dash) or it'll display wavy lines throughout the picture. http://www.x2vga.com
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
There are video cables that connect to the XBox and generates a VGA output for monitors. The XBox doesn't have a true VGA output unless you run some of the modchips and hacked firmware. Those adapters use the HDTV signals from the XBox which are just as good of a quality as a true VGA. Regardless, you would only be running the XBox at 640x480 so even a decent quality LCD monitor with composite inputs would look just fine for your purpose.
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
thanks for the help guys
