Results 1 to 2 of 2
Thread: Xenarc contrast and brightness settings
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Can someone with a Xenarc please tell me if this is the correct behavior....
    My screen is not connected to any inputs and when i go into the OSD i canot alter the contrast or brightness settings from 0. i assume i am doing it right (enter menu, press sourse until the contrast/brightness is pink and then use the volume up and down arrows). I know the volume buttons work as when not in the OSD they change the volume up and down.
    I am having possible cable troubles so i don't know if these settings are only adjustable when there is a signal input to the channel being altered.
    Mar 2005
    My GAIN screen (same as Xenarc 700IDT) from LinITX does the same. It seems to store the settings per mode. For a while at least. So it makes sense that while there's no signal, then there's no reason for it to change the values. Those values don't affect the menu brightness anyway. IIRC you can change the backlight brightness, as that's not stored per mode.
  1. setting screen brightness and contrast permanently
    By G35Pimp in forum LCD/Display
    Last Post: 07-27-2007, 08:54 PM
  2. lilliput brightness issue
    By fallnangel in forum LCD/Display
    Last Post: 06-11-2005, 08:22 PM
  3. Brightness and contrast video in VB
    By farolfo in forum Software & Software Development
    Last Post: 11-09-2004, 07:44 AM
  4. Fried PSONE with too much brightness? Help
    By greenglo in forum LCD/Display
    Last Post: 07-20-2004, 07:09 PM
  5. Lilliput forgetting settings?
    By Magma in forum LCD/Display
    Last Post: 04-21-2004, 09:52 AM
