this screen is an lvds screen, it is a 12.1" widescreen, I think it's 16:9. it is from a dell 700m
laptop that I will be installing in my car to replace the p4 currently installed. I looked at all of my options to go with a low
power, low heat design, & the via seemed to anemic to replace a p4, & Istarted looking into mobile processors, as they have all of the attributes that are needed in a car install. I looked into the commell board, but in the end I decided a centrino laptop would have everything I was looking for.
I originally just planned on chopping the laptop up & installing it to the lilli, but in taking it apart I held this screen in my hands & the smoke started coming out off my ears, hmmmm, the rest is what you see here for consideration...... turns out that the dell ati board is awsome, & it is bundled with this rotating utility that makes this 80X1280 possible. I am really thinking of seeing if I can get an 8" screen that will interface with the laptop board the way this one does(direct lvds), & try to keep the clean factory look of my current install, I'm a little afraid this larger screen install my start to look a little TOO over the top, but then again It may also wind up being pretty cool.
since I'm not sure I figured to ask you guys what your thoughts were. I do have the ability to install this screen as I have the skills to build, & I own a body shop with body men & painters on staff, but it will involve modding & ultimately painting the dash pieces which to me takes away from the clean factory look of the moulded textured original abs black dash, which I have already went to great lengths to preserve.
to install this screen the way I would install it will take alot of work to get it to look "right", & i'm also trying to decide if the end results are going to be worth the effort...........
OPINIONS PLEASE>>>>> I don't normally give a **** what anyone else thinks of my stuff, but here I'm hoping to get input from others to help me decide...........
