Page 21 of 29 FirstFirst ... 11121314151617181920212223242526272829 LastLast
Results 201 to 210 of 282
Thread: 800X1280 narrowscreen???
  1. #201
    Oct 2004
    NY
    that's pretty funny..... I only got as far as buying an asortment of variable resistors & a few photo resistors..... there still in a radioshack bag somewhere.....
    I'd have to do some research on that one... there has to be a solution, even if it involves a circuit that will give you steps instead of full true variable... I'm pretty sure that a circuit can be built for this easy enough....
    another option is to actually have it computer controlled, which the more I think about it, the more this may not be too impractical.....
    boris, what would it take to have a variable resistor(photocell) to be an input to a serial port, & have a variable resistance output to control this?
  2. #202
    May 2005
    Rochester, NH
    Haha, thats exactly what I did.. buy the photoresistor 5 pack at ratshack... I also picked up some voltage regulators and various parts to make a power supply to feed my liquid cooling system which wants a standard pc based molex.
    I don't think that resistance output is what we are looking for though... remember that the function of the pot or resistor or photocell is to reduce the voltage on the control pin... meaning, you put 5k resistance... you feed it like 1 volt... you put no resistance you feed it 5 and it goes out... you feed it infinite then it is 0 volts and full bright.
    That being said...0l33l , how hard do you think it would be to hook a say 0-5 volt reference varried by the photoresistor to the serial port or something and get an app to translate that data into a 0 - 5 volt output?
  3. #203
    May 2005
    Rochester, NH
    Ok, so I'm not super convinced that I want to get into the computer controlled dimming anyways, so I talked to the supplier and he said he had heard of it being done... but he didn't know so he was going to contact the manufacturer and ask their engineers to give us a solution... He said he would get back to me early next week.
    Also got my new screen today! Very pleased.. its got a matte screen instead of the mirror screen that my 7" wide had... this should help with viewability as well. I also have gotten all my liquid cooling stuff orderd and they should be here shortly... I also located my aluminum and it will arrive shortly. I'm only waiting on my diming circuit and 3 more batwings to be available then I'll have all the stuff in place to attempt my solution.
  4. #204
    Oct 2004
    NY
    did you order the led's from the place I gave you the link to?, If so, your probably talking to zak, right?... I did speak to him a while ago about this & he told me that the manufacturer was working on a solution for this back then..... I never followed up....
    oh, & I was using my carputer all day during the day today, & had it in the direct sunlight for a while, you'll have no problem with visability in a convertable with this, it's so bright it looks like paper in the direct sun... hard to explain, but much more than just readable, it looks good
  5. #205
    May 2005
    Rochester, NH
    Very good, I'm glad to hear this! I did buy from Ledsupply and Zak.
    I have had a setback however.. my new screen is defective... I finally figured out that its the cable, but none the less its not functioning properly and I have to wait till I can get it replaced I guess.
  6. #206
    Dec 2005
    Dismantling alpine head unit?
    turbocad6, how tough was it to separate the screen on the alpine head unit? Was it just one single ribbon cable? Are you using the same cable or did you extend the wires?
    I'm in a dilemma right now trying to decide between basic head unit & carPC or just a super touch display based head unit. I've obtained a used factory head unit that I plan on gutting. I also have a great spot up on the dash for a touch screen to come out of.
    Either I go with a separate basic head unit (alpine 9856?) and then have a carPC screen come up out of the dash or I could go with an alpine D310 and partially dismantle it. I mount the small D310 screen behind my factory radio display and I have the main alpine screen come out of the top of the dash.
    thanks!
  7. #207
    Oct 2004
    NY
    you won't be able to easily move the screen that far... when you take the head unit apart it's a half din unit & an upper screen assy... take the screen assy apart & you can mount it above the half din base, but that's pretty much as far as you can go without extending the ribbons, which would be a real *****.. check my sig. for my install, I have a bunch of pictures of the head unit disasembled
    there may be a possibility of extending the face from the half din main board, but the main board to the lcd ribbon is 10-11" approx...
    If your head unit is up high & the top of the dash isn't far then maybe.... I have a cadillac that I drove before this truck, & I did what your talking about , but with an earlier style head.... cva-1003.... I still have it sitting in a lot, I can get pictures to show you how that worked out, if your stuff is close enough then it's do-able... that car was able to pop the screen out of the dash though, partially because the top section was recesed from the bezel that the head mounted to.... & there was just enough reach.... & even then it was tough, I had to have the screen pivot kinda like a trans am headlight for reach, assembling that is kinda tough to do.
    If I had your choice of either/or, I'd go with a vga & a carpc for sure
  8. #208
    Oct 2004
    NY
    ....O.K., so I go & decide I can't go without the touchscreen any longer.... it's sitting in my office paid for & collecting dust... the biggest holdup is that I want to take the whole screen apart when I do it, so I decided to forget that at the moment & just get the touchscreen in....
    all it took was a few hours... some chopping & grinding of the dash & bezel to acomdate this, as it's really a 15" touch overlay... a 12.1" widescreen touch overlay is not available in capacitive anywhere, so this turned out to be my best option.... calibration will make this work perfect, which it does btw
    so I remove the alpine head unit & the screen to cut the dash, then re-install it as I reassemble.... nothing that I haven't done many times before, except all of a sudden my alpine screen don't work!!
    just a white screen.... this sucks.... don't know wtf happened.... I think I found another d300 on ebay... supposed to meet the guy to pick it up if he ever e-mails me his info.... this is like getting a whole bunch of parking tickets at the same time..... total waste of cash..
    anyway.... this is how the glass touch panel fits....
  9. #209
    Oct 2004
    NY
    sorry for the chopped photos... I'll fix them later.....
    the touchscreen works great..... & it doesn't affect the viewability of the screen one bit really.... if anything I think it might actually be a little better as it has some kind of anti-glare coating with a polorized layer.... it looks awsome in direct sunlight... I'm very happy with it..., now if I can just get a new alpine to chop up I'd be set
  10. #210
    May 2005
    Rochester, NH
    excellent, glad to hear that worked out well! Looks great in the light too... can't wait for mine... I recognize that little blue pot hanging out... must be the dimmer too bad on the alpine however... that kinda crap really sucks and makes me angry when it goes down.
    Oh, and holy cow man, don't tell me those marlboros are from today alone!
