Page 27 of 29 FirstFirst ... 17181920212223242526272829 LastLast
Results 261 to 270 of 282
Thread: 800X1280 narrowscreen???
  1. #261
    Oct 2004
    NY
    finally sparked her up tonight in the car for final setup & stuff... I can't say enough good things about this display... it's incrediable... so sharp & clear, from absolutely anywhere... anytime you can see the screen, you can see whats on the screen clearly... from outside through the side windows... easily readable... from inside the car in the normal seating positions it's just perfect... this is ust with the one oe ccfl!!, when I kick the leds on high the screen is so bright it lights up my whole interior... it's so friggin bright it just looks sick though, not washed out at all, just super super bright, can't wait to see it in the sun
  2. #262
    Mar 2005
    NY
    I'm going to be doing LVDS as well...pm/im me about any pointers man. GREAT job. I loved how it looked when i saw it.
    And guys, NYC isnt' so bad. The more you flaunt it, the more you are susceptable to lose it if you go into the wrong neightborhood. Its just that simple! I've left $5K of electronics in my unlocked celica cause i KNOW no one would jack it becuse it doesn't look like anything of worth would be there .
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  3. #263
    Oct 2004
    NY
    hey Dyer, what's up... I've learned quite a bit, & gained some resources when it comes to lvds, I even went as far as developing my own 4x4 lvds switching matrix/multiplexer for lvds with 4 different inputs able to switch at will to any one of my 4 outputs(screens)... only one in existance afaik, controlled with a microprocessor... more info about that in my install thread..
    I didn't put anything here for it, cause this thread is just the led backlight screen portion, but as an update/addition for anyone interested, I am putting a total of 4 lvds screens in my van on the multiplexer, with dual motherboards & a bunch of other wild stuff... check my install thread for more info if interested in seeing this
    I'd be glad to help you... what size screen are you shooting for? I do have a bit of surplus, not much, but maybe I can help there too
  4. #264
    Nov 2006
    Very slick looking. I'm thinking about doing something along the same lines, except I'll be installing it in a traditional widescreen orientation. I might not go quite 12.1" but we'll see. I plan to completely remove the area in my truck where the radio sits now, as well as the surrounding items, drink holder, cigarette lighter, power point, ash tray, a/c vent. This would leave me with a hole approximately 12" w by 8" h. I'll then do whatever fiberglassing nessicary to make it look clean. Seeing as I have no rear seats, this will be my only display.
    If you would be so kind, could you please provide me with the dimensions of the screen itself?
    I have two dell laptops I could canabalize for parts but the screens are 14" so I'd have to get creative with some sort of an enclosure for it to work.
    Also, if you wouldn't mind I'd like to pick your brain a bit on building my audio system. I've got two JL 12's and two pio 6x9's. I'll be adding 5-1/4's to replace the factory rear speakers. I've yet to decide if I'm going to go with a combination amp, or run a separate mono amp to my subs. I will not be running a HU whatsoever, all audio will be supplied line level from the carputer.
    As for budget, I'd like to keep everything (cpu, lcd, remaining stereo components) around $1000-1500. However I won't let budget impair my quality, and if anything the lcd and cpu will wait until I can afford them. In the meantime I'll just feed my stereo with a portable mp3 player or a laptop.
    Thanks for any input you could provide me. I truely respect all the work you've put into your vehicle and the passion that goes along with it.
  5. #265
    Newbie TruCypriot's Avatar
    Feb 2006
    UK, East London
    Would be funny if you could put the LCARS menu system from star trek on it lolol dont see a reason y not!
    - Forget headunits, its all about CarPCs -
    Progress {|||||||||---}
    Helix 5ch Amp @1850w
    Helix 17cm Component speakers x 2
    Audiobahn 12" Sub @400w RMS
    boot mod
  6. #266
    Nov 2005
    TurboCad6,
    Hey just read 90% of this and man what a project!!! I just had a thought.. Did you ever consider putting a sheet of Electroluminesent paper behind the LCD for back lighting? (If you did and I missed that post I appologize.)
    As i said this was just a thought, but theoretically if it worked you could possibly keep LCD's in their original enclusure and just mount the invertor on the back.
    Curious to here your opinion.
    Jam
    If it's broke fix it!
    If it ain't broke IMPROVE it!!!!
  7. #267
    Dec 2006
    Wow!!
  8. #268
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Congrats turbocad, you made hackaday.com with your LCD fabrication skills.
  9. #269
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Congrats on the hackaday feature! I was pleasantly surprised to see that up there on hackaday this morning after your message in one of my threads just yesterday:
    Quote Originally Posted by turbocad6 View Post
    wow, that hackaday site is pretty cool, haven't seen that before...
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  10. #270
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    yea i seen it to.
    haha
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
