Page 7 of 29 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 282
Thread: 800X1280 narrowscreen???
  1. #61
    Oct 2004
    NY
    there are copper tubes running through this aluminum coldplate....... the radiator for this system will be mounted outside of the cabin along with the pump....... end results should be a relatively cool, high bright screen that is also silent.... no fan noises inside
  2. #62
    Oct 2004
    NY
    these little suckers are supposed to really light up....... 35 of them should be really something.... this is turning into a project & 1/2, but should be the only 12.1" narrow liquid cooled lvds lcd on these fourums...or anywhere else for that matter
  3. #63
    Oct 2004
    NY
    more work on this... I'm using a 1/4" copper plate as a heat spreader... this is the begining of the whole assy... next on the list is getting a drill press to start machining & tapping....
  4. #64
    Oct 2004
    NY
  5. #65
    Oct 2004
    NY
    and...
  6. #66
    Oct 2004
    NY
    almost ready to light her up.... a lot of machining & drilling.. the led's are mounted... I have 20 to start with but build this to be upgradable to a total of 36.... since I don't want to take this apart again I pre-drilled for the extra rows just incase.... first let's see what 20 of these can do....
  7. #67
    Oct 2004
    NY
    this should work out real nicely I hope
  8. #68
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    肚子笑痛了
    S60 Install
  9. #69
    Oct 2004
    NY
    from what I've been told... this is how some screens were done for military aircraft... but with luxeon 5's!!!!!! I don't expect to have that much sun hitting my screen
  10. #70
    Oct 2004
    NY
