Page 1 of 29 1234567891011 ... LastLast
Results 1 to 10 of 282
Thread: 800X1280 narrowscreen???
    Oct 2004
    NY
    O.K., this is my latest idea under construction & I'm looking for opinions here.
    i am planning on replacing my lilliput 8" with something that has a little more screen area, a 12.1" widescreen turned sideways, to give an end user resolution of 800X1280 max.this will give the approximate same thing as an 8" over an 8" without the seam . One problem I will have is that I can't find anyone that can provide a touch screen overlay for this widescreen, so I may have to go without it initialy.....I think I can live with this since i have a convienient mouse in my center console. another problem I see is that no one provides a front end skin in anything like this resolution.............wonder how much work it would be to modify something like this. first picture is my truck as-is & last is a photoshop image of what it is projected to look like, what do you think both good & bad..............I would like some opinions please.......... btw, this screen is lvds & run directly off of my pentium m dell laptop motherboard, & will be modded for highbrite with "xennon backlight daytime booster", which I will document here as it is done............
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    thats cool as, let us know details of progress
    Signature: [==||========] 20% complete
    Oct 2004
    NY
    the lcd......
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    whered the other pictures go?
    Oct 2004
    NY
    ...& the final rendition, I made the screen a lttle to large, but you get the idea.....
    Oct 2004
    NY
    another "view"........
    Raw Wave lostreception's Avatar
    NY
    awesome idea id just be concerned with thieves im gonna put 2 touchscreens in my van got one now waiting to be hooked up
    but im just concerned on how to mount it in such a way thats its an absolute ***** to remove/steal
    keep us posted
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Res Master
    Where did you get the screen?
    BIOSTAR M7NCG400 : AMD-M ATHLON XP 2400+ : VANTEC AIRFLOW : 512 MB 3200 RAM : XENARC 700TSVB : MSI 128MB DDR MX4000 : MONSTER 300 WATT INVERTER
    Maximum Bitrate Cartunes's Avatar
    May 2004
    Quote Originally Posted by redmage
    ditto!
    1992 z71 Chevy
    Oct 2004
    NY
    this screen is an lvds screen, it is a 12.1" widescreen, I think it's 16:9. it is from a dell 700m laptop that I will be installing in my car to replace the p4 currently installed. I looked at all of my options to go with a low power, low heat design, & the via seemed to anemic to replace a p4, & Istarted looking into mobile processors, as they have all of the attributes that are needed in a car install. I looked into the commell board, but in the end I decided a centrino laptop would have everything I was looking for.
    I originally just planned on chopping the laptop up & installing it to the lilli, but in taking it apart I held this screen in my hands & the smoke started coming out off my ears, hmmmm, the rest is what you see here for consideration...... turns out that the dell ati board is awsome, & it is bundled with this rotating utility that makes this 80X1280 possible. I am really thinking of seeing if I can get an 8" screen that will interface with the laptop board the way this one does(direct lvds), & try to keep the clean factory look of my current install, I'm a little afraid this larger screen install my start to look a little TOO over the top, but then again It may also wind up being pretty cool.
    since I'm not sure I figured to ask you guys what your thoughts were. I do have the ability to install this screen as I have the skills to build, & I own a body shop with body men & painters on staff, but it will involve modding & ultimately painting the dash pieces which to me takes away from the clean factory look of the moulded textured original abs black dash, which I have already went to great lengths to preserve.
    to install this screen the way I would install it will take alot of work to get it to look "right", & i'm also trying to decide if the end results are going to be worth the effort...........
    OPINIONS PLEASE>>>>> I don't normally give a **** what anyone else thinks of my stuff, but here I'm hoping to get input from others to help me decide...........
