I'm trying to determine if the following situation would work:
I need a system display. Normal OS, applications, etc.
I need a small LCD, such as the Xenarc, to accept an image window from within an application, such as the image window from Photoshop, which would be scaled to fit the display using either native controls on a GeForce4 MX4000 or through Powerstrip.
I need to run a second display with the same image as will be on the Xenarc, but not using the scaling function, as it will be a full-sized lcd display.
Can the window be mirrored like this but scaled on only the Xenarc? If so, what would the setup be?
