Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Successful Dual Video outs
    Raw Wave lostreception's Avatar
    NY
    Ive been searching on this topic quite a bit lately
    Alot of projects always start out saying " I want 2 screens one with video and one with gps" and so on but not many ppl come back to say "hey i got it working!"
    what im wondering is cpu usage wise, power consumption, and specs wise
    if you have dual video outs on your system
    **NOT CLONED VIDEO BUT 2 TOTALLY DIFFERENT DISPLAYS (NVIEW)**
    what type of setup do you have
    is your system stable
    is the opus or your psu supporting your setup
    has anyone mastered this basically
    My main thing is epia is appealing but looks like video will be choppy if it can be done at all, HOWEVER then its a constant battle over power consumption and the inevitable "will the opus power this" thread.
    BTW ive done power consumption calculators but i get diff number on diff calculators
    SO if you have a functioning dual vid out system if you could post your specs and even trials and errors you went thru i think it would help out a bunch
    *im not looking for ppl to do the research for me i am planning an Asus A7N8X-VM and Mobile Athlon 2500+ system but im also confused on whether i need to put a second Geforce vid card, any housebrand vid card or if one of these or these will work*
    -Lost reception
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    well at home i have 3 LCDs 2 vid cards You just set it as dual veiw and then you can have apps open in the A B C screen, i recomend a GeForce card. Or just get a shuttle barebones and if its the right one you will have dual VGA.
    Just get a Video card with dual heads and it should work.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    NY
    the Asus A7N8X-VM supports Nview apparently
    From the Asus Spec Page
    _____________________________
    VGA -Integrated GeForce4 MX GPU
    -Integrated TV encoder
    -NVIDA nVIEW dual-display architecture
    -Support DVI (AGP-NV-DVI) and TV out (AV/S) cards
    I think thats confusing me a little
    the board only has from what i can see only has one vga out
    whats required for a second display one of the things i posted previously or a second gforce OR just a vid card
    i know this can be done i was just hoping to see some ppls working examples and get some feedback
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    the dual head is only fromt he VGA and tV out. There is only one nForce2 IGP mATX board wheich has dual VGA out supporting nview and that is an Epox model.
    The only ways you could do it are
    a: run a VGA and svideo/rca screen
    b: put a PCI graphics card in and run both - but this is always crappy
    c: buy a dual head AGP card and disable the onboard graphics - easiest option
    d: buy the Epox!
    Mar 2004
    Bristol
    hey thats a good deal...
    1990 Jeep Cherokee
    NY
    it is a consideration ive made but i dont like losing my serial port ive heard the USB replicators sometimes dont work properly. otherwise its a great board
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    NY
    hold up a second, possible correction from above correct me if im wrong because if im not this seems to be the perfect board (for me)
    I read on the specs page
    ___________
    I/O CONNECTOR:
    PS/2 Mouse and PS/2 style Keyboard Printer, Audio-in/out, MIC connectors COM1, COM2, Game Port by extra Cable
    _________________
    scouse i saw a post on here this was your concern as well
    If I am reading the right specs it seems i can add just a cable and be done ?
    EDIT again
    someone on newegg said "I wish it supported clock multipliers because then you could use Mobile Athlons. Other than that, solid board."
    does the wire trick solve this or no im not much of an overclocker...
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Mar 2005
    LA,CA
    I dont know how they do it, I heard that they had custom hardware from manufacturer and their mobo manufacturer...plus there is tons of programming, but I cant wait
    http://www.digitalicetechnology.com/dss.html
    I guess someone is already on it.
    Noobiiiii
    with much knowledge!
    50% completed demo car for Dice, Inc.
    Quote Originally Posted by BNolm
    yea i talked to the owner of that company one day and it sounds cool...
    1990 Jeep Cherokee
  1. Replies: 21
    Last Post: 02-10-2005, 11:39 PM
  2. Which dual display video card? Ps1 gurus
    By Tred in forum LCD/Display
    Last Post: 02-09-2005, 10:53 PM
  3. Dual Monitor/Split video for Via M10000?
    By glxyjones in forum General Hardware Discussion
    Last Post: 12-29-2004, 08:30 PM
  4. Dual Video Displayed
    By li_runer in forum LCD/Display
    Last Post: 12-01-2004, 02:57 PM
  5. Dual monitor video card.
    By Three13 in forum Newbie
    Last Post: 05-16-2004, 03:45 AM
