Results 1 to 6 of 6
Thread: Lilliput VIDEO drivers question
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    I'm in the process of optimizing my system and was running through all my system properties to verify that my drivers were all set correctly. My Lilliput is set as the "Default Monitor" which leads me to believe I don't have the Lilliput video driver installed. I have all of the other software that comes with the Lilliput driver (downloaded as an auto-extracting .exe file) and I read SOMEWHERE on here that some of the Lilliput drivers are better than others.
    I've read that there are a lot of different versions of the Lilli drivers. Can anyone clarify which is the best and explain why they have that opinion?
    And can anyone shed any light on why "default monitor" is my only selection?
    Help with either or both questions is appreciated.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by R32 JUhl
    Erm, there is the touchscreen driver... But no monitor profile that I have heard of, if that's what you mean???!!!
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Nov 2004
    North Atlanta
    Quote Originally Posted by stevieg
    Cool! Maybe I'm not missing something after all.
    Would still like to hear from those "in the know" about the differences in the various drivers...
    Aug 2003
    Warwickshire, UK
    TOUCHSCREEN is the one that people usually have to upgrade.
    http://www.egalax.com/support-drivers.htm
    I would get the 3.2.3.3122 personally though the 3.2.1.2925 should work fine and is the one I would tell you to get
    4.0.0.1103 does work fine but it's an even newer beta version so probably less reliable.
    Nov 2004
    North Atlanta
    Thanks for the help. That clarifies the topic for me! I'm going to practice the "ain't broke don't fix it" method on this one. But it's good to see the differences recorded. FWIW, I currently have 3.2.3.3122 and I'm not having any trouble with touchscreen. Recently discovered the right mouse button in the tray - nice touch.
    Newbie Stray's Avatar
    Feb 2005
    Belgium
    I've been using 4.0.0.1103 from day one and haven't had any problem with the driver so you can also get this one.
    Stage 1:[||||||||||||||||||||] 100%
    Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
  1. need help with lilliput RCA video input
    By CDesigns in forum LCD/Display
    Last Post: 04-04-2007, 07:33 PM
  2. Video Mode Question [direct button]
    By camsgs3 in forum FrodoPlayer
    Last Post: 12-14-2004, 01:19 AM
  3. EPIA M9000 Video drivers....
    By jusatry in forum General Hardware Discussion
    Last Post: 11-21-2004, 03:47 AM
  4. Linux drivers for Lilliput Touchscreen?
    By Visual Echo in forum LCD/Display
    Last Post: 11-07-2004, 08:05 AM
  5. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
