Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Lilliput hell
    Low Bitrate Mush's Avatar
    Dec 2004
    UK
    Lilliput hell
    After looking at some of the custom installs i decided to give it a go myself.
    i think i did a semi decent job but ended up with a white screen.
    so i sereched the forums and found that the common problem is the 40 pin ribbon
    I then managed to blow the small 1 amp fuse, but managed to replace it(soldered a 1 Amp fuse fire across it).
    After waiting for almost three weeks i got the ribbon cables from digitalww but odered the wrong ones. so i redodered the right ones and got them with-in a week (thanks armen).
    Still no luck with the white screen. after spending about three hours trying to reseat the damm cable i thinks its capoot. so if no ones got any ideas any one intrested in a possible fried lilliput or any one out there with some lilliput spares??????
    Lilitput 7" touch screen :-( , Epia -M 256ddr, Opus150w,
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    I have a TView and I had a similar issue.. with mine when I start the truck it turned white instantly.. even when the power buttons was not on.. however if I connected the vga cable to my PC it would work normal..
    something happened with my ground, so I connected my vga ground and auto ground line together.. works fine now.
    so maybe that will help
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Dec 2004
    UK
    I havent connected the lilliput back to the pc yet becuase of the white screen. if the lillput is not connected to anything it should normally say no signal on a black screen shoudent it.
    Nov 2004
    Ham Lake, MN
    yes.. my screen did the same as yours .. try grounding the VGA cable.. just touch the housing to a ground source.. that should do it..
    -shawn
    Shawn
    Dec 2004
    UK
    :-( no luck . any other ideas out there??
    Nov 2004
    Ham Lake, MN
    bummer.. you could try connecting it to your board.. but do that at your own risk ..
    of course I fried 3 PSu's so far.. so .. well yeah..
    the problem seems so similar.. don't lilliputs have a warrenty?..
    Shawn
    Dec 2004
    UK
    gose out of the window the moment you start gutting it, respraying it , bonding it with your dash , then again theres probably no harm in asking is there?????
    I got mine form ebay posted from hong kong. i dont think it would be worth my time chasing the guy and trying to expalin what ive done as his english is very limited (a lot worser than mine).
    i think im having a really **** week. i just recived a DVD/VCD/MP3 etc player this morning which was supposed to have Aux in (180 uk / almost $300 and its of ebay again) ive just emailed the guy expalining what aux in actually is and hes telling me to take to a professional. thank the lord for paypal! haa haa haa
    so any one with a cheap lilliput out there????
    Nov 2004
    Ham Lake, MN
    it's got to be something simple.
    sometimes if I just take something like this apart .. and look it over.. I'll see a loose connection or a burned out component.. ya know..
    I wish I knew more about electronics other wise I'd buy it from ya and fix it..
    Shawn
    FLAC J187's Avatar
    Nov 2004
    Boston
    I had the same problem. I figgited with trying to reseat the stupid thing for like 45 minutes, before I finally got it. The screen will display one of the following:
    All white if the ribbon is not pluged in at all
    Black w/ "no vga" or fuzzy black if the ribbon is seated improperly
    good picture if properly seated.
    The only way I found to seat it was to plug into the wall and plug into my spare PC and fidget til I got a desktop. Now, while taking it apart I screwed up the ribbons so I have to order those. AHHHHH.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Nov 2004
    Ham Lake, MN
    with some soldering and rainbow ribon wire.. you should be able to nix a broken ribbon .. but I'm cheap
    Shawn
  1. Replies: 118
    Last Post: 10-22-2010, 03:05 PM
  2. lilliput, gone to heaven, maybe hell
    By faiz_23 in forum LCD/Display
    Last Post: 10-04-2004, 04:25 PM
  3. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 08:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
