Results 1 to 4 of 4
Thread: Question about 3M sticky pad with LCD mounts
    Low Bitrate sxt173's Avatar
    Feb 2005
    New York
    Question Question about 3M sticky pad with LCD mounts
    Quick installation question:
    Those sticky 3M or other pads that come with the mounts on most LCD's (that half circle, cut out looking thing), do those leave smears on dashboard or plastic when you remove???
    I'm going to mount my LCD on dashboard using the stick-on-pad (3M in my case), but will look for another option is there is glue-gunk left over when I want to remove the mounting bracket.
    Thx!
    Feb 2005
    New York
    anybody??? Nobody used a double-sided sticky pad for their LCD??????
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Although the residue that is left behind id easily removed with Goo Gone or some other remover, i wouldn't recommend sticking your monitor on your dash for at least a few different reasons.
    1. It will block your field of view.
    2. It will be very visible to unwanted eyes like thieves or cops.
    3. It will be in direct sunlight at least part of the time making it unreadable.
    4. Not sure how hot it gets where you are but when that adhesive gets hot it will probably fall right off. when the weight of your monitor gets pulled one way or another taking a corner and your monitor comes loose, slides across the dash and out the window.
    ATVMS.com
    Feb 2005
    New York
    thx. I'm actually going to stick it in front of my shifter, away from eyes except for mine...
    Pictures to come soon in installations section
  1. lcd question
    By beinkken in forum Newbie
    Last Post: 03-10-2004, 03:49 PM
  2. Newb LCD question
    By TiziteLayinLow in forum LCD/Display
    Last Post: 03-04-2004, 06:28 PM
  3. 3m usb touchscreen controler question?
    By kalito in forum Input Devices
    Last Post: 02-23-2004, 07:45 AM
  4. Question for LCD users
    By entities in forum General Hardware Discussion
    Last Post: 07-31-2000, 08:33 AM
  5. LCD troubleshooting question
    By cyalume in forum General Hardware Discussion
    Last Post: 11-24-1999, 02:12 PM
