Results 1 to 4 of 4
Thread: Dell laptop, lilliput screen, and 800x480 resolution, possible?
    Mar 2005
    Pomona, CA
    I am in the process of putting together a carpc, but am not sure if I will be able to get native resolution on the lilliput with my dell laptop.
    I have installed powerstrip, but am not familiar with the exact setup or if it is even possible.
    Also, I have read long and hard and could not find a specific enough answer for my particular case.
    Thanks.
    Elsewhere
    Quote Originally Posted by sivart321
    Thanks.
    Go to the advanced options of your display properties and select list all modes. It will tell you whether you can display at that resolution.
    You can also uncheck the option to hide modes that the monitor can't display. Windows won't pick up your Lilliput specifically, but as a default monitor.
    And you want it at 75hz, I believe, not 60hz.
    How about the Wiki?
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    if you fail finding 800x480 listed under "list all resolutions" button, you may want to try your luck with PowerStrip too.
    Mar 2005
    Pomona, CA
    I don't even see "list all modes" anywhere
    nm, found it... not there :-(
    What do I need to do in powerstrip to get it to work?
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Lilliput 7" @ 800x480
    By ryguy in forum LCD/Display
    Last Post: 12-19-2004, 08:11 PM
  3. WMP full screen resolution
    By Maņana in forum Software & Software Development
    Last Post: 09-04-2004, 04:29 AM
  4. Replies: 0
    Last Post: 06-15-2004, 12:01 AM
  5. 800x480 on lilliput 7" / linux?
    By hkrebs in forum LCD/Display
    Last Post: 03-25-2004, 03:58 AM
