Results 1 to 3 of 3
Thread: Xenarc troubles
    Jan 2005
    Ft. Worth, TX
    Xenarc troubles
    My Xenarc display always displays arbitray resolutions. When I set the video mode for 800x600 it tries to do 7** x 5**. With 640x480 it displays some other resolution. What in the world could be causing this? Thanks in advance.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Make sure you have the correct video drivers installed, check the web to make sure that your drivers are the latest and "greatest"..
    Now check and see if there is a BIOS update that you need to apply, if so apply it.
    Make sure that all connections are tight and secure and that there are no conflicts in "device manager"
    If none of these help at least you have narrowed your field of troubleshooting to just a hardware issue...
    Try plugging the xenarc into another system and see if it acts the same way..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Raw Wave
    Jun 2004
    On the beach
    I've also found that when the screen can't detect the correct resolution it is because the wrong frequency is being sent by the grapahics card, changeable by going to Display Properties, Settings tab, Advanced, Adapter tab, then click List all modes and choose an alternative Frequency.
    Hoep this helps
  1. Xenarc direct cause of audio noise- help!
    By shidarin in forum LCD/Display
    Last Post: 04-19-2008, 10:53 AM
  2. Basic Question: How do I get my computer to display on my Xenarc
    By PDiddy in forum General Hardware Discussion
    Last Post: 01-13-2005, 08:23 AM
  3. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  4. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
