Results 1 to 3 of 3
Thread: Gm Denali HU interface - recommendations???
    Mar 2005
    Is the Yukon Denali HU VGA or RGB???
    Ok, I have done some research, but need some help. I was looking for a PAC module VCI-GM2 to display video (CarPC) on my built in Bose NAV Touch screen. However; I don't want to pay 350 bucks for a NTSC to RGB converter. My car PC has VGA out, so why not bring it right into the touch screen through a VGA switch? Why go from VGA to NTSC back to RGB??? However, how do I bring my VGA from my PC to RGB in on my unit? Do I need a converter? I need to buy a ribbon cable interfacing from the stock nav to the screen. or convert the one in the unit. It seems like the Pac module diverts five leads in the ribbon to the NTSC/RGB switch... Has anyone looked into this? I couldn't find any info this detailed.
    Thanks in advance,
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Im not a pro on this but if RGB and VGA are the same signals, meaning just need some splicing of wires will do the trick, then you will need to just make a relay box thatcontaining a relay for every wire. Then have a switch to trigger all the relays at once and go back and fourth between nav and carputer. My friend did this with his G-35 but he wasnt using a carputer, jsut a dvd player, so he needed the converter in addition to the relay I just mentioned.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    8" Lilliput touch screen
    dual optimas
    battery isolator
    15" screen
    My Truck
    Mar 2005
    I have found some conversion units form VGA to RGB for around 50-100 bucks so I am ok here. However, I am not totally sure that the nav/screen is RGB or VGA. The VCI-GM2 unitis using 5 wires, which makes me beleieve RGBHV, not RGBs or RGsB, but I don't know for sure. help anyone?
  1. Interface with The GM BCM???
    By Jailer in forum General Hardware Discussion
    Last Post: 07-09-2008, 06:23 AM
  2. Help in Kenwood HU Changer Interface
    By tch in forum Input Devices
    Last Post: 04-19-2006, 07:18 PM
  3. Kenwood HDM-555 WinCE 4.2 HU - 20gb HDD/GPS/DVD/MP3/WMA/Ipod Interface
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-16-2005, 01:41 AM
  4. Need Help - Yukon Denali HU w/ OBD II and camera
    By Anders in forum Input Devices
    Last Post: 03-04-2005, 12:44 PM
  5. Need Help - Yukon Denali HU w/ OBD II and camera
    By Anders in forum General Hardware Discussion
    Last Post: 03-04-2005, 08:38 AM
