Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 129
Thread: Xenarc 700IDT In DASH 7" Touch Screen IN STOCK!
  1. #101
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Just wanted to post my initial thoughts on the 700IDT. I just purchased it used from another mp3car member.
    As soon as you hold the unit, you know it's manufactured with high quality materials. The unit is a freaking brick - it doesn't use the cheap plastic that most other non-motorized units use. Instead, it's constructed mostly of metal and assembled very nicely. Product design isn't that great (as I'll expand upon below), but it's a very solid unit.
    The wide power input option is great. You can basically hook it up directly to an accessory or battery line in your car (i.e. any unregulated 12v).
    The unit's pop-out mechanism is solid as well. It works pretty well. To open the monitor, you just give a gentle push in the area with the fake blue button (you can see it in a picture of the front of the unit while it's closed). The monitor pops out and goes upright in one motion. No more pulling out and adjusting. To close it, it's as simple and folding it down and pushing it back into the mechanism.
    The unit is also very long. It's about 3-4 inches longer than my Pioneer Premiere HU. The brackets in the back provide the basic clearing room for the cables. There is obviously a huge product design issue here - why didn't they just recess the cables into the unit, especially considering how large it is. You will need a DEEP dash to install this properly.
    The BIGGEST gripe I have with the unit is that it does not have standard ISO/DIN mounting holes. Sure, you get a nice sleeve, but there are no standardized mounting holes. It seems like they drilled two rows of holes on both sides of the unit. None of the holes lined up with my Lexus factory stereo bracket (which is ISO spec).
    Other than that, amazingly, I think the unit has a few bad pixels. I may have to send it in to Xenarc to get fixed. And the touchscreen software is a little screwy. I got real used to the old touchscreen software on my 700TSV and I've had a tough time getting my settings to the way I had them on my 700TSV.
    -HD
  2. #102
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Quote Originally Posted by hd54321
    I agree.
    Yep.
    This right here is my bigges complaint. The connector locations in the back are not optimal for fitment. The power connector is in the center, and it interfered with my bracket. I had to beat my metal brack back behind the dash in a little to get that to fit. Then the VGA connector, it sticks out too far as well. I agree the connectors should have been recessed.
    -HD
    My unit has been great. I just need to be educated on hooking it to a cleaner power souce. The touchscreen software has behaved flawlessly for me. Then again this is my first experience with touchscreen software, so take what I say as you may..
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  3. #103
    Jun 2004
    Los Angeles
    Update: I had to send my 700IDT back to Xenarc because of an issue with the bottom of my desktop appearing on the top of the screen. I was using the Powerstrip settings in the Xenarc FAQ along with a Radeon 8500 video card (Catalyst 5.2 drivers).
    Xenarc confirmed the issue and recommended I change the Powerstrip setting for Horizontal Geometry > Front Porch > 40
    They also replaced my whole unit because of one dead pixel. Talk about service! They were awesome! The replacement unit looks brand new. Kudos to Xenarc!
    -HD
  4. #104
    Maximum Bitrate PORTUGAL's Avatar
    Oct 2003
    PORTO
    Install Pics
    Road Runner
    Gladiator divx
    Touch games
    smoke visualizations
    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
  5. #105
    Oct 2004
    Please more pictures!
    Oh my God! You have a Jetta (or something that's close enough)! I have an '01 Jetta, and I really really want to buy one of these screens, but...
    Does it interfere with the cup holder? (Stupid question, but my idea is that an unfolded cup holder (with cup!) might help prevent theft by obscuring the screen.)
    Can you take some pictures of the screen in light, so I can see how it fits in the dash? Closed?
    Thank you so much!
    Chris
    cej102937
  6. #106
    Oct 2003
    PORTO
    I dont have the digicam right now, but if you buy this monitor you will have to make some modifications on the monitor because it doesnt fits completly....
    The vga conection is to big, so you must push your dash further back or simple make some modifications on the monitor itself and push the vga conection inside the monitor.
    I think a user has done this, the monitor its great(to bad about the size with the vga conection) but i have a crack on the touchscreen and i will have to send it back...
  7. #107
    Oct 2004
    Thanks.
    It looks like it interferes with the cup holder, since it does stick out a bit. Would you happen to have a view from above with the screen closed?
    Chris - cej102937
  8. #108
    Jun 2004
    Los Angeles
    Out of nowhere, while I was touching the LCD today, the touchscreen cracked. I can't freaking believe it. I wasn't even pressing it hard.
    I hope Xenarc will fix this.
  9. #109
    Oct 2003
    PORTO
    Same thing hapenned with my Xenarc, for the second time.....
    I think it some kind of problem with the construction of the monitor itself, the crack started at the botom corner of the monitor both times
  10. #110
    May 2005
    Zagreb, Croatia
    Isn't Xenarc supposed to be of superior quality compared to Lilliput?
  1. Wide Screen format touch screen
    By belezeebub in forum LCD/Display
    Last Post: 03-22-2005, 11:35 PM
  2. in dash touch screen in Vaux Corsa (UK)
    By m2rv h in forum Show off your project
    Last Post: 09-06-2004, 09:57 AM
  3. Xenarc Touch Not Working
    By MSUC5Vette in forum LCD/Display
    Last Post: 08-18-2004, 12:42 PM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. Replies: 5
    Last Post: 02-28-2004, 12:45 PM
