Page 13 of 13 FirstFirst ... 345678910111213
Results 121 to 129 of 129
Thread: Xenarc 700IDT In DASH 7" Touch Screen IN STOCK!
  1. #121
    Jul 2003
    Milan, Italy
    Yep It seems they solved it
    Yep It seems they solved it.
    I received a new screen from cartft.com and it's fully working from about 1 month.
    Bye!
  2. #122
    Jun 2005
    Phoenix, AZ
    I've had mine for a few months with no problem.
    scott
  3. #123
    Jan 2005
    Xenarc 700IDT Loosing Brightness Settings
    I seem to recall my 700IDT used to save brightness preferences after switching the unit off. It now no longer seems to do so. Any ideas? The
    default brightness (33) is insufficient and therefore needs adjusting each
    time I'm in the car.
  4. #124
    Jun 2005
    Phoenix, AZ
    Mine does not and never has saved those preferences, but I'd also like to know how if it is supposed to.
  5. #125
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Mine never craked, but the ribbon cable in the back got pinched by the back of the screen housing. I was talking to a friend of mine who has the same screen, and appearently they fixed this issue as well. I got my RMA number, just need to return my unit. Here are the details:
    http://www.mp3car.com/vbulletin/show-off-your-project/27445-my-hp-pavilion-n5190-f2025a-laptop-carputer-project-post584831.html
    Scroll down a little for the pictures.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  6. #126
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Just cause there's a lot of folks watching this thread...
    As was mentioned somewhere else, I think there is a break in lots of the 700IDT.
    I had a couple of problems (fit and tilt), details here. My old serial number was A0022, and my new on is A0081.
    I have better luck. It FITS!!! It's a tight fit, but it does. Before, it physically wouldn't go it since it was 1 sheetmetal thickness away from fitting. The new one I got fits in the cage. It needed some convincing, and it don't need to secure it since the fit is so tight, but it fits. So I don't know if it's possible, but you might want to ask if the serial number is high or low. I just bought mine from logicsupply.com, and it was a pretty low #. Got a new one direct from xenarc, and it was high.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  7. #127
    Mar 2005
    Yeah, mine also cracked after just a few months of owning it. I sent it in and they're sending me the motorized one instead.(mp3car.com) So I hope I have better luck with that!
  8. #128
    Jul 2003
    Xenarc has a motorized one now?
    Current build! Here
  9. #129
    Jul 2003
    Quote Originally Posted by LinuxRacr
    http://www.mp3car.com/vbulletin/showthread.php?p=584831
    BTW, my friend came into town last night from OK, and I saw his 700IDT. The location where the ribbon cable gets pinched still has that sharp lip on the back of the screen. Here is his screen in his MP3 BTW:
    http://www.msprotege.com/forum/showt...80#post2148780
    Current build! Here
  1. Wide Screen format touch screen
    By belezeebub in forum LCD/Display
    Last Post: 03-22-2005, 11:35 PM
  2. in dash touch screen in Vaux Corsa (UK)
    By m2rv h in forum Show off your project
    Last Post: 09-06-2004, 09:57 AM
  3. Xenarc Touch Not Working
    By MSUC5Vette in forum LCD/Display
    Last Post: 08-18-2004, 12:42 PM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. Replies: 5
    Last Post: 02-28-2004, 12:45 PM
