Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 81 to 90 of 129
Thread: Xenarc 700IDT In DASH 7" Touch Screen IN STOCK!
  1. #81
    Mar 2005
    Jonesboro, Arkansas
    i picked up a 700idt and it seems to be working pretty well.
    so far my only complaint is that every now and then the blue volumn box will come on and not go away. i have to turn off the lcd for about 30 secs and then it works fine again.
    Portugal: mine came with a liyitek touch screen. I did not install the drive that came with it. i believe it was version 3.3.2. on liyitek's website they have a new driver 3.3.4. i installed that driver and in the liyitouch v3.3.4 program and can adjust several things in the "Parameter" tab. Just make sure to press "Alt-A" to unlock the buttons so you can save your changes. (i had to adjust mine twice, because i didn't notice the note the first time.)
    for those of you wondering about the inside of it, i've had mine apart...i couldn't resist on the inside of the faceplate there is an brack the is 5.25" wide and 0.5" high..prefect for a slim line dvdrom. there are also four screw holes drilled and tapped that would allow you to mount the dvdrom.
    instead of mounting the dvdrom inside the lcd, i decided to move the circuit board closer to the front (about 2"). then i cut the back panel so that i could poke all the cables through. i also remove the U-brackets on the back panel. this allowed me to push the lcd further into the dash.
    i apologize if this info has already been post on another thread. i didn't see anything in this thread, so i thought i would put in my two cents.
  2. #82
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Good post. Good info there. Yeah, I took off the bottom cover as well in the front, and found a nice empty space.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  3. #83
    Maximum Bitrate PORTUGAL's Avatar
    Oct 2003
    PORTO
    Quote Originally Posted by muskrat_waxer
    Good post indeed, did you took any pictures ??
    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
  4. #84
    Mar 2005
    Jonesboro, Arkansas
    no pics yet. hopefully soon though
  5. #85
    Jul 2003
    Quote Originally Posted by raphizzz
    hi LinuxRacr,
    did you check the cable?
    and did that solve the problem?
    Yes, I did this weekend, and it did solve the problem. The color is as clear and crisp as it should be.
    Current build! Here
  6. #86
    Low Bitrate raphizzz's Avatar
    Brussels - Belgium
    good news!
    was the cable badly connected?
    what did you do in particular?
  7. #87
    Jul 2003
    Pulled the screen out of the dash after it wouldn't display from any computer, and found that the cable never latched properly to the hooks on the back. It eventually came completely off. I reconnected it, and made sure the hooks had it anchored, and all was good.
    Current build! Here
  8. #88
    joZ
    joZ is offline
    Newbie joZ's Avatar
    Jan 2005
    Sweden
    found a motorized in dash at a swedish import companys homepage.
    specs:
    KDV-301 7" In-Dash Skärm med VGA Touch Screen funktion.
    SPECIFIKATIONER:
    *In-Dash fully motorized 7" complete digital Display.
    *Display Resolution:800 RGBx480.
    *16:9 and 4:3 Aspect Ratio.
    *Standard VGA input(15 pin D-SUB)
    *Video System:PAL/NTSC.
    *2Video Inputs/2 Audio Inputs.
    *Built-In TV Module for TV1,TV2,TV4.
    *FM/AM Radio (RDS)
    *Bright:400 Nits.
    *Contrast Ratio:300:1
    *User-Friendly connections for DVD,GPS,PCs,Back Kamera,Video Game.
    *Remote Control.
    *Touch panel with USB Interface.
    *4 Wires resistive Touch Screen Panel (USB)
    *Adjustable backlight level for night-time use.
    *Power Supply:10.5-14V DC.
    *Dimension:178x155x50 mm.
    *Sound control:Volume,Balance,bass,treble,fader.
    *Anti-Shock mechanism.
    *All Information displayed on the screen.
    *Adjustable color,contrast,brightness.
    *Colors:Black,Silver
    Doesn't seem to have tilt left/right thoug. but it has radio and (swedish) tv.
    anything exept the tilt that isn't good on this screen? (I'm pretty new to all this)
    /jonaZ
    I wanna die in the sleep like my grandfather, not screaming and yelling like the passenger in his car.
  9. #89
    Jul 2003
    How about you share the website link?
    Current build! Here
  10. #90
    Newbie vwremglx's Avatar
    Feb 2005
    Syracuse, NY
    I'm feeling lucky' on google for "med VGA Touch Screen funktion" ' :-)
    MacMini into a VeeDub..
    In Planning Stages
    Central New York Volkswagen Club
  1. Wide Screen format touch screen
    By belezeebub in forum LCD/Display
    Last Post: 03-22-2005, 10:35 PM
  2. in dash touch screen in Vaux Corsa (UK)
    By m2rv h in forum Show off your project
    Last Post: 09-06-2004, 08:57 AM
  3. Xenarc Touch Not Working
    By MSUC5Vette in forum LCD/Display
    Last Post: 08-18-2004, 11:42 AM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 12:54 PM
  5. Replies: 5
    Last Post: 02-28-2004, 11:45 AM
