Results 1 to 5 of 5
Thread: Powering LCD that has a clock
    Nov 2004
    I just got an Innovatek IN-7031 (motorized in-dash, 800x600 - but no vga).
    Monitor seems to work well, but wanted some input regarding power.
    The unit has a Battery + lead as well as an ACC + lead. The in-line fuse is on the battery lead, and it appears that the ACC lead is only used to tell the unit to turn on.
    The problem I have is the unit has a clock built-in. I wanted to run it off my PSU for a regulated +12V, but that doesn't keep the clock current as the PSU shuts off the power.
    Should I:
    1.) assume that if the set it up this way they designed it to run off 14V,
    2.) install a lilliput style egg voltage reg that is connected directly to the battery. (will these draw much more current then the clock on it's own?)
    3.) put in a capaciter and a relay and run it off the battery overnight, but use the relay to switch to regulated power as soon as the PSU starts.
    Thoughts?
    Simon.
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    I personally would assume that, since its an "in-dash" unit, the manufacturer has asumed you're going to hook it up to the 12VDC power in your car, and have built the unit accordingly, or have at least provided an appropriate 12VDC power supply.
    Take a closer look at the specs for the display and what came with it.
    Nov 2004
    specs
    That's what annoyed me the most - neither the manual or the unit have any voltage specs in/on them. The essentially 1 pg manual simply says what colour is for what purpose on the wiring harness.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    the thing is fused.....hook the that thingup to the car 12v
    PC Components:
    My work log
    Dec 2004
    Maryland
    i think he is more concerned about not what the wires do, but if it can recieve non-regulated voltage....and I'm saying more then likely it can
    PC Components:
    My work log
  1. 8.4" LCD in WRX dash.
    By Giuliano in forum LCD/Display
    Last Post: 08-07-2010, 04:27 AM
  2. Wild Things PSone LCD to PC
    By godzi11a in forum LCD/Display
    Last Post: 11-22-2005, 08:13 PM
  3. Powering my LCD
    By Mogwai in forum Newbie
    Last Post: 10-11-2004, 11:02 AM
  4. graphic LCD or PSOne LCD
    By hannibal in forum LCD/Display
    Last Post: 09-26-2004, 09:40 PM
  5. Powering LCD
    By marsjell in forum LCD/Display
    Last Post: 03-09-2002, 11:29 PM
