Results 1 to 5 of 5
Thread: Digital WW screen problem
    Feb 2005
    HI guys,
    I got all the pc fitted in my car and the screen, but wheni turn it on the screen come on says AV1 then waits like 10 secs and says power off. Wot am i doing wrong?
    It seems like its if not getting a vga signal or something?
    Has any1 else had this problem or know how to solve it or what i'm doing wrong thanks.
    This is the screen (http://www.digitalww.com/DWW-7VGA.htm)
    Maximum Bitrate Rundell's Avatar
    Have you tried changing the input on the unit? Needs to be in VGA mode
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    Low Bitrate fishy's Avatar
    Oct 2004
    sydney
    press the V1/V2 button twice more.
    When you first turn it on, wait for AV1 to appear onscreen, then press the button, you will notice AV2 will appear. Press it once more and it will change to PC mode (PC will appear instead of AV1 or 2).
    Then the screen will auto-detect your settings and refresh rates.
    Hilux Surf (4runner) install
    false floor in rear housing;
    4 channel amp
    600w cont. inverter.
    Also- DigitalWW 7VGA indash
    headunit for FM/AM,DVD,SVCD,CD,MP3
    P4 3.0 with low profile AGP card.
    4x4" speakers (splits) in factory locations
    BU-303 GPS
    Feb 2005
    I tried pressing the buttons but nothing seems to happen.
    Variable Bitrate lerandell's Avatar
    Mar 2004
    Ennis,TX.
    sound lilke to input button is not working. Even with no inputs it should at least switch and show you "av1" - "av2" - "vga" - then back to the start.
    did you put the lcd in yourself? If not get with Armen to see about repairing it.
    Randell Kelly
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  2. Lilliput Fuzzy screen, resolution problem?
    By vcbb5 in forum LCD/Display
    Last Post: 07-04-2004, 01:13 PM
  3. digital ww tm701L flat flex
    By mutilator in forum LCD/Display
    Last Post: 03-31-2004, 03:46 PM
  4. Replies: 5
    Last Post: 03-30-2004, 10:53 PM
  5. Replies: 38
    Last Post: 01-03-2003, 11:11 PM
