Results 1 to 4 of 4
Thread: Xenarc Touchscreen Problem...
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I've done some but couldn't find anything helpfull...
    I have several problems with the touchscreen... Since I've burned my usb hub and replaced it with a different one I have problems...
    The PC is in the trunk so I have to use extensions.. I've tried simple extensions and powered ones... The problem is that from time to time (maybe 10 min or 2 hours) the touchscreen won't work (other usb devices work), but if I replug it, it will work...
    How do you connect usb devices with the pc in the trunk??
    Jun 2004
    GREECE/Athens
    I've double-checked all the wiring but came to nothing!! It is really annoying!!
    Constant Bitrate Malenko's Avatar
    Jul 2004
    Newark,De
    this is just the geek in me speaking, but hook up the +12v power source (in the USB cable)to a toggle switch (involves cutting the extention wire), when it stops working, flip the switch off then back on.
    just a thought.
    you could try using thicker powered USB cables, that could strengthen the signal?
    [IIIIIIIIII]95%
    Dynamix 7" LCD Touchscreen Monitor
    VIA Epia M10000 Motherboard
    Samsung 40 gig 2.5" Hard drive
    Slimtype LSC-24082K DVD/CDRW
    1024MB DDR RAM
    Morex 3688 case w/ psu
    Jun 2004
    GREECE/Athens
    the usb cable has +5v... i tried powering off and back on the screen and it works then...
    but after a while it may stop working again!!
  1. Lilliput Touchscreen Driver Problem.
    By gleinz in forum LCD/Display
    Last Post: 01-12-2007, 12:30 AM
  2. Xenarc 800TSV 8" VGA Monitor with touchscreen and video inputs
    By therussman2002 in forum Classified Archive
    Last Post: 03-03-2005, 09:42 AM
  3. FS: Xenarc touchscreen &controller, backlight, inverter
    By Shadow in forum Classified Archive
    Last Post: 11-16-2004, 09:48 PM
  4. Lilliput Touchscreen Problem
    By BrUTaL in forum LCD/Display
    Last Post: 10-23-2004, 11:52 AM
  5. Xenarc Touchscreen Drivers without XF86?
    By millec in forum Input Devices
    Last Post: 05-26-2004, 03:00 AM
