Results 21 to 30 of 35
Thread: Lilliput 7" Cable help needed. (Bad 9pin DIN)
  1. #21
    Jan 2006
    I've just fixed my cable as it was showed at the first post here, but it did'nt work, i got 2 red wires that did'nt go anywhere, one went to the 4pin on the usb, and the other one was on the other cable, that one i did'nt find out where went, what can i have done wrong? i've checked the connections 2 times, and it's all connected as they should
  2. #22
    Jan 2006
    hm....just think i found out what my problem was, i don't have the DIN9 contact, i have the one with 10 pins that you screw on...
  3. #23
    Mar 2005
    I put the web page back online
    Hi,
    I noticed that accidentally erased a page with pinouts from my server. Now it's back:
    http://www.astaltsev.com/CarPC/liliput_cable.htm
    Dmitri
  4. #24
    Jan 2006
    i've done like the plan tells, but it dont work, but as i said, my connector got 10 pins, not 9 as the DIN9 connector
  5. #25
    Jan 2006
    hmm....i have a DIN9, my bad
    but it didn't work, i had all the connections where it should be after the scematics AND after a original cable (i testet it)
    what can i have done wrong?? i welded all the earth connections together ofcourse
  6. #26
    Mar 2005
    look at my previous post (on prev. page):
    Notice - THERE IS NO shield connection between USB, VGA and monitor 14 din connectos. I don't know why, but there isn't.
    I first noticed this when I was powering my Lilliput from separate power supply - not from PC's 12V. If you don't connect USB cable to PC - image is flickering. Bad ground.
    I don't know if it helps. My oppinion - there should be one COMMON ground, but that's not how original cable is.
    Also, the very first pinout in this topic had an error. I don't know if it's fixed.
    has correct pinout (at least it helped FireAnt).
    Make sure you don't have short circuit where it shouldn't be.
    Good luck.
  7. #27
    Jan 2006
    it works i just had to separate som of the ground points, i didn't read that post that well ;-)
  8. #28
    Constant Bitrate Grimoire's Avatar
    May 2006
    Fayetteville, NC
    No one answered where to buy a replacement, IS there a place?
  9. #29
    Jun 2006
    Quote Originally Posted by Grimoire
    http://www.carcomputer.co.uk/touchsc...dex.php?cat=10
  10. #30
    Newbie EL_GRECO101's Avatar
    Mar 2007
    Keratsini - Greece
    Urgent!!! Lilliput GL701 - VGA Wire Connection!!!
    Searching here in the forum enough but also in a lot of other sites unfortunately I did not find any answer for how these three wires should be supposed connects???
    The first three (*Red =1 / *Green=2 / *Blue=3) I believe that they are connected right…
    But the *Black - *Brown - *Yellow, I have not occupied where they should go;?;?;?
    Virtuousness & Daring...!
  1. 9-pin mini din extension cable for lilliput
    By ummagawd in forum LCD/Display
    Last Post: 03-21-2005, 05:06 AM
  2. FS: 7" Lilliput VGA Module
    By calvincbr in forum Classified Archive
    Last Post: 02-25-2005, 10:04 PM
  3. I need a lilliput 9 din vga cable
    By Skeeter in forum Classified Archive
    Last Post: 10-29-2004, 02:16 AM
  4. 800x480 on lilliput 7" / linux?
    By hkrebs in forum LCD/Display
    Last Post: 03-25-2004, 03:58 AM
  5. 7" REDANT SCREENS (bad pixel) CHEAP
    By dscustoms in forum Classified Archive
    Last Post: 06-26-2002, 11:04 AM
