Results 1 to 10 of 17
Thread: I cant read my lilliput...
    Mar 2005
    Ok, So I got it installed and working, the video drivers are installed for my Epia board. However i'm only getting 2 resolutions, 800x600 and 1024x768. At 800x600 I cant even read the text on my 7" lilliput, The letters are all destorted (Almost as if you vertically squished a picture of text, the letters show up as blocky or not at all). It also wont allow me to adjust the refresh rate away from 60.
    It is showing up as 3 monitors under Device Manager...
    1. Default Monitor
    2. Microsoft Digital Flat Panel
    3. Generic Television
    I've looked all over the CD and cant find a correct driver for it.
    I've searched for driver updates on the forum but all I've come back with are updates for the touch screen aspect, which my touchscreen is working fine. I just cant see what I'm touching.
    Edit: This hasnt been modified yet, Its straight out of the box.
    Mar 2005
    Are there actual monitor drivers I should be using that arent included?
    Mar 2005
    Quote Originally Posted by joshthepilot
    Did you run that auto setup on the lilliput itself when you put it in 800x600? Its in the built in menu.
    Are you talking about the "Auto Tune" feature?
    One thing I did notice, My Display settings on the computer are set at 800x600, but when I look at the Lilliput menu under information, its saying 1024x768. I cant seem to figure out how to change it though.
    Also, any clue why I cant adjust the refresh rate above 60? I thought most people were running 85 with this? Id guess I'd need monitor drivers for that to happen, but I cant seem to find any.
    Mar 2005
    Ok, I just hooked the Lilliput up to my main computer and the problem went away.
    Does the onboard video on the Epia10 just suck that much? Or is there a a fix for it?
    Constant Bitrate elmo's Avatar
    Mar 2005
    Staffordshire, UK
    My advice would be, remove all drivers, restart... tends to fix most hardware glitches in windows, the amount of peoples display i have sorted with that is astronomical, cant hurt to try
    www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
    Mar 2005
    Quote Originally Posted by elmo
    There arent any screen spcific drivers, and I've deleted the drivers windows picks for it on more than one occasion.
    Its just showing up as stated in my first post..
    1. Default Monitor
    Still looking to answer these:
    What is the Monitor supposed to show up as in Device Manager?
    Are there specific monitor drivers for it? (Screen)
    Do I just use the drivers what windows gives me?
    I've been searching around and I cant seem to find any info.
    I'll probably just cut my losses and modify the case to accept a PCI video card.
    Mar 2005
    Well, let me ask another question... How many people CAN read the Epia10000 at 800x600 using onboard video?
    I can read it at 1024x768 but as soon as I drop it to 800x600 all hell breaks loose with the text.
    Maximum Bitrate Rundell's Avatar
    Its fine on my epia MII 10000
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    Mar 2005
    Quote Originally Posted by Rundell
    How does the 7" Lilliput display in Device Manager? If you dont mind looking, I'd appriciate it. Are you able to adjust the refresh rate away from 60?
    Is the MII 10000 different from the M10000 that is in the mp3car store?
    Quote Originally Posted by Daven
    Mine says: Default Monitor and I can change the refresh rate, mine I normally set to 75
    The difference in the two is I have a PCMCIA and a Memory Card slot. don't think there is any other difference
  1. simple lilliput ribbons question
    By avidan in forum LCD/Display
    Last Post: 01-27-2005, 09:28 PM
  2. Replies: 13
    Last Post: 07-26-2004, 12:25 AM
  3. FS: Parting out Lilliput
    By 047025n in forum Classified Archive
    Last Post: 06-26-2004, 08:52 PM
  4. Anti-Glare : Lilliput vs. Xenarc
    By badandy4you in forum LCD/Display
    Last Post: 05-21-2004, 02:27 PM
