Results 1 to 4 of 4
Thread: Strange lilliput video interference. Best way to combat this?
    I received my 6' 9-pin din extension cable yesterday and connected it to my lilliput last night. If I push the connection together firmly, my display on the lilliput goes really blurred/ghosted (unreadably so). I wiggle it a bit so it's not quite a tight connection, it goes mostly ok but I'm getting a lot more instability of the display. Strangely it comes and goes - revving the engine tends to make it worse but after the cars been on for a while it largely disappears.
    Anyone experienced this and have any insights? Currently I have the PC running of my own dc-dc regulator connected to a PW-200V and the lilliput off it's egg in the cigarette lighter socket.
    So you reckon the ghosting will go away when I have the lilliput running of the same dc-dc regulator (my plan). I'm still flummoxed by the fact it suddenly gets so much worse when I make the connection tighter!
    Still not got around to wiring the lilliput into my custom dc-dc regulator in the PC, but getting close. Ferrite cores on the extension cable didn't help - and I'm now wondering if I even need the extension cable - I think the original cable will actually just be long enough for my PC's final mounting location under the passenger seat.
    Here's what I've noticed though - if I'm idling and then switch on the headlights, the interference goes away briefly and the lilliput egg stops making the warbling whine it otherwise makes continuously. The interference doesn't go away if I'm not idling and switch on the headlights.
    Time to fix up the wiring so the lillput is running off the same power as the PC and see if it does indeed fix things.
    Quote Originally Posted by joshthepilot
    Once that egg is gone, your troubles will also be gone.
    And indeed they were. Just finished hooking up the lilliput to the DC-DC regulator I built for the PC this morning before coming into work. And the lilliput display is now rock steady. I did initially see one line of (mostly) blue pixels across the top. That disappeared when I first restarted the PC - kinda wierd.
    No more egg, nor more whine, no more interference!
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. need help with lilliput RCA video input
    By CDesigns in forum LCD/Display
    Last Post: 04-04-2007, 07:33 PM
  3. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
  4. Weird problems with video and ME 2.1
    By Rireal in forum Media Engine
    Last Post: 02-20-2004, 07:33 PM
  5. lilliput video In sensitivity??
    By spankmebumbum in forum LCD/Display
    Last Post: 12-27-2003, 05:25 PM
