Results 1 to 7 of 7
Thread: Video signal for 2x LCD's on xbox?
    Mar 2005
    Hi everyone.
    I'm currently planning to install a xbox in my car, together with 2 7" monitors in the headrests. I'm planning on using the 12v power from the xbox(harddrive) to power the monitors. Using a 300W powerinverter to power the xbox. However, I'm not sure how I'm going to get the AV signal to both monitors at the same time. Haven't seen a xbox-to-2xRCA cable so I guess I need some sort of splitter... Going to use it for games and maybe dvd...thatever the kids want...
    Anyone?
    dr_k
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Quote Originally Posted by dr_k
    Hi everyone.
    Anyone?
    dr_k
    Walmart sells an RCA splitter, for less than $5. You're not going to find an all-in-one-cable. You just need to connect components. Like I said, wal-mart, sells a cheap one.
    Mar 2005
    joshthepilot: i'm guessing that will work, but i'm not sure if that will give me a crap picture or not. Then again, it is a rather inexpensive way. I'll see if i can find it in my local gadget store here in oslo, norway.
    dr_k
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    Splitting the video signal with just a Y adapter will definitely affect the quality. You wouldn't really notice it with audio but your video would suffer. Radio Shack has an amplified audio/video splitter for $44, catalog number 15-1172. I have one and use it for multi-monitor presentations. It runs off of 9VDC so it can easily be adapted for use in the car. And it gives you two more outputs for future expansion.
    EDIT: Oops, missed the Norway reference. Well, I don't think Radio Shack has made it out there but look for something with similar specs.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I split the video to two headrest monitors with a simple Y-splitter and the video looks absolutely no different with one monitor on or both on. I'd try it first before you invest in a splitter/amplifier.
    Fabricator
    Mar 2005
    thank you for all your tips, however, i might have the wrong view on this... For quality vga is better than rca, so if i want to have 2x vga out of the xbox...then what do i do? the x2vga will only give 1 vga output...
    dr_k
    Mar 2005
    Well, in that case, TigerDirect sells a VGA splitter cable for $10 (http://www.tigerdirect.com/applicati...173&CatId=467). If the picture quality doesn't seem good enough, then a powered/amplified splitter is also available (http://www.cablesnmor.com/monitor-splitter.html).
  1. Alpine IVA-C800
    By Skippman in forum LCD/Display
    Last Post: 09-08-2007, 03:15 AM
  2. Cleaning VGA video signal
    By Destin in forum General Hardware Discussion
    Last Post: 12-28-2006, 11:17 PM
  3. 6.8" Video LCD's for $350
    By gguy in forum Classified Archive
    Last Post: 04-06-2001, 03:29 PM
  4. How do I clean my video signal?
    By TheDingo in forum General Hardware Discussion
    Last Post: 12-14-2000, 04:42 PM
  5. Text Readability on 5.6" LCDs?
    By mrmunsell in forum General Hardware Discussion
    Last Post: 12-04-2000, 10:52 PM
