Results 1 to 6 of 6
Thread: Bad tview T-700TS
    Newbie pugstyle's Avatar
    Feb 2004
    Denmark
    Question Bad tview T-700TS
    I got a screen from digitalww.com for about a half year ago and now im going 2 use it but the touch won't work its about 5 cm from the mouse should be can i try 2 calibrate but it won't change it what is wrong whit it ???
    Carputer Status Not installed
    Car : Peugeot 306 style
    Screen : Lilliput 7" touchscreen
    Case: homemade plexi
    Motherboard: VIA Epia M10000
    Power Supply: Mastero MK-4 (still waiting for some parts)
    Radio: not sure yet
    Software: XP, MediaCar
    Aug 2002
    Eau Claire, Wi
    im haveing a similar problem with mine. it has been working just fine for a few months and then all of a sudden i started having calibration issues. now sometimes the touch doesnt work at all. Im going to try to reinstall the drivers and hope for the best, but i suspect the touch panel is bad. its getting very frustrating though, and just in time for meet next weekend too!
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Aug 2002
    Eau Claire, Wi
    well i just finished reinstalling all the software and drivers for my touchscreen. I found out something somewhat interesting along the way. Upon installation, my problem remained almost the same. The calibration was still way off, but at least it worked consistantly. I went into the 4 point calibration and it made it more acurate, but still not as good as i would like, so i tried the 25 point calibration, when i was done i got an error " EEPROM access failed!" which leads me to beliave that the 25 point calibration information as actually stored on the touch controller itself! ( i could be wrong, but its a reasonable assumption). i tried again and it worked. now my alingment was almost perfect, so i didnt mess with it anymore. So it seems to be fixed for now, I'll report back if anything changes.
    So now the question is what causes this problem? the touchpanel, the controller, or the driver/ config utility? or the combination of them?
    Is there another utility that may be better then the touch Kit software?
    Aug 2002
    Eau Claire, Wi
    Problem returned after about an hour of use. I have to continuously realign it. i'm pretty ****ed. i dont know what the problem is, but i think its the touch pannel. does anyone know if i could get one of the 7" pannels from digitalWW and use it wih the existing controller?
    Aug 2005
    Dear Meyer64:
    I have the same problem with my tview. Did you find a solution?
    Robin Hou
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Thankfully the touchscreen controller is completely seperate from everything else..it shouldn't be too hard to just replace that one part..
  1. Bad Battery or Bad Connection or Altenator?
    By sniz55 in forum General MP3Car Discussion
    Last Post: 01-30-2005, 06:40 PM
  2. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. *one* bad pci slot? also, bad NIC?
    By InFix in forum General Hardware Discussion
    Last Post: 11-28-2002, 12:49 AM
  5. 7" REDANT SCREENS (bad pixel) CHEAP
    By dscustoms in forum Classified Archive
    Last Post: 06-26-2002, 11:04 AM
