Results 11 to 20 of 27
Thread: Question for those that put together their Lilly motorized enclosure
  1. #11
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    The cable pictured comes with new lilliputs. Some of the old ones might be a little shorter. However I think all cables should be able to reach the back of the housing. I can send you a new one along with your T Panel.
    Armen
    Quote Originally Posted by Defiler
    I have a question for you guys...
    Is the cable from your original Lilliput as long as the one in this picture?
    http://www.digitalww.com/Lilliput_To...h/DSCF4879.JPG
    Mine is nowhere near that long and it doesn't reach to the opening of the back of the case.
  2. #12
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by digitalww
    Armen
    That would be great. Could you please add more pictures too? I see a red wire that got soldered on one of the cards and I don't know which spot it got soldered to. I thought there was going to be little to no soldering and there is a lot more than I was lead to believe. I suck at soldering and I know I'm gonna be up ****s creek and in more debt before this is screen is done.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  3. #13
    Sep 2002
    ILLINOIS
    If you are just extending the backlight cable then there is very little soldering. I am sure you can do it. I will try to start on the guide ASAP because a lot of you are starting to receive the hosings.
    I will send you the cable tomorrow.
    Armen
  4. #14
    Jan 2002
    Temple Terrace, Fl.
    Along with the TS?
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  5. #15
    FLAC SFiorito's Avatar
    May 2004
    no, it's not the ribbon cable. i've fought with it before... and checking the connector with a volt meter there's no signal going through at all. looks like it's the fuse (right next to the DC plug, right? 1A KOAC??). 12V going in, nothing coming out... what are my options? where can I find a replacement for this fuse? I did a preliminary search and didn't find much. Not really sure what to look for either besides a 1A fuse. Is KOAC the manufacturer? Thanks.
  6. #16
    Sep 2002
    ILLINOIS
    Shipped out today.
    Armen
    Along with the TS?
  7. #17
    Sep 2002
    ILLINOIS
    I can send you a new fuse.
    Send $3 to [email protected]
    Armen
    Quote Originally Posted by SFiorito
  8. #18
    Jan 2002
    Temple Terrace, Fl.
    Shipped out today.
    Armen
    Just got the Fed Ex e-mail. THANKS!!!
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  9. #19
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Armen, can you check your emails please.
    Mine arrived with 'issues'
  10. #20
    Dec 2004
    Exclamation
    Armen
    If you are going to extend the inverter cables, remember is high voltage.
    Don't just use any old wire, use a HV wire rated for this & it's better to double insulate it with a second layer of heatshrink (especially where it passes through the mechanical parts)
    Take care!
  1. Replies: 30
    Last Post: 07-28-2010, 10:14 PM
  2. Question about this enclosure
    By churnopol in forum General Hardware Discussion
    Last Post: 03-20-2004, 09:17 AM
