Results 1 to 4 of 4
Thread: Anyone try component video over vga?
    Mar 2005
    Has anyone tried using a component to vga adapter to run a DVD player or PS2 (xbox, GC etc etc) to a car VGA lcd monitor?
    This would be really sweet as you could have progressive scan dvd playback in a car - which currently is not possible using car lcd monitors (I have yet to see a single LCD monitor designed for cars with progressive scan capability or component video inputs). I suppose (although it would be a bit much) you could do hi-def as well using a car VGA lcd monitor (maybe 720P?) - though I'm sure this has not been tried yet.
    Also - has anyone tried using the S-video inputs on the Starvision and/or Lilliput LCD 8" monitors? Do they look allot better than composite video input from a dvd player or another source? I know using a regular television that S-video produces a much less "shaky" picture and it also eliminates dot crawl which is visible if you look close to the picture.
    Would love any feedback from anyone with a car vga lcd. Starvision, lilliput and Xenarc. I am deciding between the Lilliput 7" and 8". I think the S-video input may be a deciding factor for movies and such - though my Starvision and LUXMA LCD's that I have installed right now look pretty good (Starvision) and awesome (LUXMA) with only composite video input.
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i have a 8 inch lilliput i bought from has vga svideo and 2 composite that what your talking about?
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Nope Component video is seperate Red, Green, and Blue inputs, usually like those found on high end graphics monitors (that use seperate inputs rather than a 15pin VGA plug), or Barco type projectors
    4x4 in a turbo stylee.
    Mar 2005
    Eskalad - yes the 8 inch lilliput model. Have you tried the S-video input of this screen? Does it look noticably better than the composite input?
    I have seen VGA to component video input adapters all over the net. They are designed to work with VGA monitors and mostly for older Digital and HDTV televisions. You can supposedly get a progressive scan image - even a 1080i image (if your monitor supports this resolution) by using one of these adapters. Being at $100 or more though makes them not cost effective and thus I have never used one.
    VGA does use a seperate RGB signal along with Lum and Chrome to the best of my knowledge. Component uses rgb and chrome and lum using seperate cables - I believe the green and blue cables use chrome and lum. I could be wrong.
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  2. FAQ: VGA Terminator for video card
    By Dima in forum The FAQ Emporium
    Last Post: 09-28-2006, 03:46 PM
  3. Xenarc 800TSV 8" VGA Monitor with touchscreen and video inputs
    By therussman2002 in forum Classified Archive
    Last Post: 03-03-2005, 09:42 AM
  4. Xenarc VGA Controller Features
    By 1300mer in forum LCD/Display
    Last Post: 07-05-2004, 01:46 PM
  5. VGA to Video out ???
    By Mastero in forum General Hardware Discussion
    Last Post: 02-24-2002, 02:38 PM
