Results 1 to 2 of 2
Thread: Rca on Lilliput not working
    Constant Bitrate blustreak's Avatar
    Jan 2004
    ATL GA
    OK so I try and plug my Xbox into one of my RCA inputs on the lilliput and it says no signal. So when I tried going into the menu on the lilliput and switching the Video so that it says RCAS but when I scroll off that option it resets it and says Video card again. I can't figure out how to make it stay at the RCA input configuration. Is there a trick to entering the option? I'll try any ideas.
    Is there anyway to set up the lilliput so you can view the Bios on it. Everytime I try and view them it says out of range?
    Also the only refresh rate I'm given an option to select is 60Hz and I'm pretty sure I have all the updated drivers because everything else seems to work just fine. Any ideas on that?
    Jan 2004
    ATL GA
    I have searched for it. My Xbox works just fine.
    I really think it's the options on the Lillipt menu. See after I go into the menu on the screen and try to change a setting, it won't stay. When I try and set it to RCA it switches to the card option. I can't get it to stay.
    That's my problem. I also have th enewest driver's from DigitalWW. Is there somewhere else I need to look because I also updated the VGA driver from Epia.
    Any more help would be appreciated
    C134, EPIA M10000, 512mb, M1-ATX, DWW-700H, Seagate 40GB, Panasonic DVD/CDRW
    Alpine ERE-180 EQ
  1. Car PC stressing you out? Lilliput not working?
    By Enforcer in forum Off Topic
    Last Post: 10-01-2004, 09:50 PM
  2. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  3. FS: Parting out Lilliput
    By 047025n in forum Classified Archive
    Last Post: 06-26-2004, 08:52 PM
  4. Lilliput Touchscreen not working
    By jjc319 in forum LCD/Display
    Last Post: 02-01-2004, 05:37 PM
  5. Touchscreen not working for my new Lilliput!
    By robutek in forum LCD/Display
    Last Post: 01-27-2004, 07:30 AM
