Results 1 to 7 of 7
Thread: custom 2din lcd - from VVTMODULE?
    Jan 2005
    Berkeley, CA
    i'm ready to move forward, except for my lcd. I have a 2din opening and want to get the 400 nit panasonic in there... do i buy this:
    http://digitalww.com/VVTModule.htm
    and have it mounted into the 2 din space by my installer? or do i need to get one that has a bezel around it? if I get the vvtmodule above, where are the control buttons?
    thanks,
    Wes
    2005 m3 coupe, carputer to come...
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    The buttons look like they are mounted on the circuit board, vs. being a daughter board of some kind. I think you would have a hard time getting an installer to mount the LCD and the buttons in a useful position.
    This looks more like a DIY project.
    You could mount the LCD in the Double Din opening behind the existing bezel of your dash. Then wire some momentary switches remotely from the circuit board to your dash.
    The circuit board is larger than the screen itself (north and south) but smaller (east and west) in the width. It really depends on your car and how much room you have behind the dash.
    AS for the brightness, I would wonder if the 400 rating is before the TS overlay is added. The overlay seems to reduce the brightness by 100 as far as I can tell.
    I think they are both the same setup, one just comes assembled, the other does not.
    Either way, it shouldn't be a whole heck of a lot of work IF you have the space in your dash.
    Hope I helped....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Jan 2005
    Berkeley, CA
    hmm - does anyone know of an installer in the bay area (or perhaps in LA area) that would handle this kind of install?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    the digitalww module is essentially the xenarc/gain screens so for measurements and more pics look in the sticky in the LCD section. New buttons can easily be soldered to the circuit board using wires and the large controller board cna be mounted horizonatally as the ribbon cale is about 6 inches long.
    Someone has recently made a very neat LCD holder using plastic etc. i think it is int he fabrication section
    Aug 2004
    Portland, Oregon
    Quote Originally Posted by pesos
    Have you thought of going to the SOcal carputer meet in April?
    Status:
    Custom enclosures
    Newbie Guide
    Mar 2005
    Pesos,
    I purchased that exact model and mounted it in a 2din opening in my 2000 Honda Accord. I made my own bezel and there was just enough room to mount the buttons so that they are accessible just below the screen but I plan on re-doing the whole thing after using it for a while because I have found that I never need access to the buttons and I would prefer to have the screen centered in the 2din opening. Just thought Id throw out my opinion, good luck.
    Mar 2004
    Bristol
    can someone answer this for me who has the screen and got it recently..and got the brighter (400nit) model.
    is the module exactly like the one on the site. ie does it have the crappy slim connector or does it have the new beefy xenarc style connector?
    also, can some please please please note down the part/model numbers on the back of the LCD modul for me.
    Cheers
    Andy
  1. 15" LCD 2001 Sierra 4x4 Ext cab
    By CPUFX in forum Show off your project
    Last Post: 07-21-2005, 09:17 PM
  2. Custom made 7" LCD trimplate for BMW e46 series
    By Mpower in forum Classified Archive
    Last Post: 07-06-2004, 12:59 AM
  3. Replies: 0
    Last Post: 07-24-2003, 03:42 PM
  4. Replies: 0
    Last Post: 03-22-2002, 07:40 AM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
