Results 1 to 4 of 4
Thread: Wierd Lilliput screen problem
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Whenever I press close to the left side of the screen, i get a ripple. Like when you touch a normal LCD, it only happens in one spot, no matter where i touch on the gerneal left side of the screen. nyone know what might be causing this?
    Quick! To the Popemobile!
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    It's probably a weak spot on the TS which is bending and touching the panel behind it when you press it.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    i get the same exact thing....doesnt seem to be effecting perfomance though
    PC Components:
    My work log
    Katy TX
    Ok, I just wanted to make sure it wouldn't damage the screen or anything.
  1. Lilliput screen inside motorized unit?
    By JayKaye in forum LCD/Display
    Last Post: 09-29-2004, 01:14 PM
  2. Green screen on Lilliput TM-701L
    By kandyman676 in forum LCD/Display
    Last Post: 09-07-2004, 04:45 PM
  3. Lilliput Regulator Problem...?
    By smonice in forum General Hardware Discussion
    Last Post: 08-25-2004, 02:36 PM
  4. Lilliput screen problem
    By Neil T in forum General Hardware Discussion
    Last Post: 08-18-2004, 10:48 AM
  5. lilliput and quality problem
    By mrzigzag in forum LCD/Display
    Last Post: 01-18-2004, 02:30 PM
