Results 1 to 10 of 12
Thread: Ident on a screen/controller...pls hlp.
    Low Bitrate sounder's Avatar
    Aug 2001
    Atlanta
    Unhappy Ident on a screen/controller...pls hlp.
    I bought a 10.1" LCD screen from Outragis off this board about a year and a half ago. Well I have lost the documentation on it, and need to get it running. I have tried searching the components and Google to see if I could get anything from the web, but no luck. What I have gathered is this: The screen appears to be a
    "Sharp b6n18b"
    "Y027BKA-B".
    The controller:
    "viewtek" "s/n 02203" ,
    "series 80" with "axiom designs"
    Taking some numbers from the bios chips on the board :
    "11s6lvnv-1.7" and "LM1205N".
    I have had no luck in my searches. The screen and controller are capable of 16m colors and 800X600 resolutions. I know that it has 500 nits of brightness. Please help me out if you can. Any documentation left or any ideas as to where to get some info to get this screen back up. Thanks for your help in advance.
    Regards, Corey Lipham
    Subject open, Subject closed.
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Post pics of the connectors.
    1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
    PC built into console
    worklog with pics: http://www.mp3car.com/vbulletin/worklogs/46359-1999-plymouth-voyager-computer-in-console-between-seats.html
    Some of my music: http://www.myspace.com/markquestion
    Aug 2001
    Atlanta
    Quote Originally Posted by joshthepilot
    Well if you have all the pieces, what exactly is the problem. Isn't hooking it all together kind of obvious?
    thanks Josh, why didnt I think of that.
    there are some wires that I do not know the voltage or load. Well let me get that straight I know the voltage of the wires, but I do not know the load. Also I have 2 Dc-Dc ps. I have one for the system, and this second one I am going to setup to run just the screen. Seeing as how I only need a 12v 5v and a gnd. I am worried about the load for the 5v line. it could be 10 it could be 1. If it is too much then this dc ps is not going to cut it for me. I once had a pdf doc on the controller, and now I dont have it. So I was just tryign to get some help on the load. Also on another note, I need to jump the second ps off of the first one. So when the PC power supply is on, so is the screens ps. Oh well, im sure there is something on that laying around.
    yea, ill go takes some pics for you. brb....
    Aug 2001
    Atlanta
    The screen will not use more than 1 amp total. When I see the pics, you may not even need to regulate anything.
    alright heres the pics....
    Aug 2001
    Atlanta
    In pic 4, that is the power supply? You measured the voltage coming out of the red, white, and yellow wires is it?
    Pic 1....you have 3 wires, then maybe 10 wires, and another 10 wires, is that right? They all go to the display? 3 wires for the inverter? Do you have an inverter?
    If its 10 and 10, then you an LVDS display.
    So you need to figure out where to attach the power supply to the controller, and connect the LCD panel to the controller, and what else. The inverter?
    well in pic one that is the controller. The wire pack on the right goes to the screen.
    Pic 2 : thats just the bottom of the controller...probably useless for all accounts
    Pic 3: close up of same wire pack
    Pic 4: yes, this is the inverter. Red 5v, yellow 12v, white |-5v|, blue |-12v|
    From the input diagram that I think I recorded right, on the power header on the controller only +12, +5, and gnd are used. but I am not absolute 100% on that. I cant remember what the pdf doc said.
    pic 5: the screen.
    Aug 2001
    Atlanta
    I wanna ditch the inverter btw. and go dc-dc, I have a 90 watt ps120 Ituner supply that I want to dedicate to it.
    Aug 2001
    Atlanta
    oh I left a pic of that out...casue that hooks up from the controller...so I need not worry about that.
    ps...eys the bl is built in....powered from a free standing module that connect to the controller off to the left.(not in pics) I am just trying to get stable correct DC power to the controller, after that im in business.
    Aug 2001
    Atlanta
    well I guess we got this solved, so you dont think I should worry about the amps on each of the hot lines, if it is comming from its own 90w supply? I think I will be safe, but I hate to go off hooking crap up and blow 400$. and have to start the lcd search again.
    Aug 2001
    Atlanta
    hmm, maybe this is an lvds setup.
    Aug 2001
    Atlanta
    ill have to break out that trusty volt meter...I think I have an old AT supply laying around that I can go test with. ill get back to you on the amps.
