Results 1 to 5 of 5
Thread: Anything wrong with just leavin the lilliput on power saver?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I got my custom lilliput installed yesterday. Rather than dealing with the auto on issue i was wondering if there's anything wrong with leaving the monitor in power save mode. I have a brand new yellow top so i'm not really worried about power drain. I just wonder if this will put added stress on the monitor.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    the lilliput will still draw more than .2 amps when it is on but not receiving a signal, ii would advise switching it off for extended periods of time
    http://www.carnetix.com/additional_i...llyCurrent.htm
    Signature: [==||========] 20% complete
    FLAC mauri's Avatar
    Jan 2004
    Power the Lilli with one relay,connect the coil of relay to the +5 or +12V (second you relay use)with the connector of HD or Floppy,and the power source for the Lilli in the switch contact of the relay.
    PC ON, power the relay,Lilli powered by the switch of the relay.
    PC Off, Off relay, Off the Lilli automatically.
    EDIT:connect one diode type 1N4007 in parallel mode to coil of the relay, Anode to -, Katode to +
    Mauri
    Woodbridge, VA
    Blog Entries
    32
    Yea i really dont wanna crack open the custom enclosure and rip the unit back out of my dash just to do this. I left it on overnight (14 hours) and it worked fine.. my car doesnt normally get breaks that long.
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by joshthepilot
    Perfect example of "The Pointless Method."
    It has speak "the genius "
  1. LED Power light on the Lilliput....
    By Skipjacks in forum LCD/Display
    Last Post: 12-24-2004, 09:41 AM
  2. Power for the lilliput
    By zmann in forum LCD/Display
    Last Post: 12-04-2004, 01:57 PM
  3. Replies: 1
    Last Post: 07-01-2004, 01:44 AM
  4. Lilliput Power Source
    By veetid in forum LCD/Display
    Last Post: 06-27-2004, 03:07 AM
  5. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
