I just got twenty 35,000mcd 10mm 80mA LEDs off E-Bay for $35. They are hella bright!
damn you, i dont have anywhere to get these CCFLs from!Originally Posted by jcdillin
yeah they are but the problem with LEDs is the small viewing angle means you need a lot of diffusion which can drastically cut the light so you need a lot of light. If you put a lot of LEDs in you can possibly cut the diffusion down. The luxeons have a good 110-140 viewing angle but they do get hot!Originally Posted by RPM_VR4
EDIT: if you are up to it though try em!
ok I just did some testing with my current diffusers
this is with a 2 tube backlight in a U shape, actually it's the backlight picture I posted a few posts back
1. I tried the panel on top with nothing but the ccfl's behind, and it was kind of bright
2. then I added 1 sheet of diffuser the brightness increased alot
3. then I added the 2nd sheet and had to rotate it to change the polarization and holy crap I cant even look at it directly
4. I added a smoked sheet of plastic to even out the lines from the diffrent polarizers
i'm trying to take some pics right now, I dont know how they will come out
肚子笑痛了
S60 Install
Here is the backlight with nothing keep in mind this is with the raw LCD panel on the backlight
肚子笑痛了
S60 Install
first diffuser
肚子笑痛了
S60 Install
with both diffusers and the smoked plastic sheet
damn camera doesnt pick it up very well
肚子笑痛了
S60 Install
so you say ti got brighter with the diffusers? how strange.not what i was expecting or had read. mybe it was an increase in the Lumns - i e light coming over a great anlge. hmmm try it with the LCD on and change the number of diffusers.
well this is a broken panel that I have, I havent been able to get my hands on a donor panel that actually works
i'm going to try adding diffrent diffusers from diffrent panels and more of them
肚子笑痛了
S60 Install
Originally Posted by Scouse Monkey
yeah it seems to be collecting the light and transmitting it straight out of the panel
肚子笑痛了
S60 Install
