Page 15 of 29 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 282
Thread: So, give us new LCD touchscreen options!
  1. #141
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Ok people because I only have 1 lilliput and limited funds
    i'm going to need a LCD panel or two from a lilliput in order to start testing this out.
    So you have one laying around you want to sell or donate just PM me.
    Even a panel from a xenarc would help so maybe something could be figured out for it as well.
    肚子笑痛了
    S60 Install
  2. #142
    Mar 2005
    kansas
    I contacted 3M as well. They should be sending the AR material to me but i couldnt get any samples of the Vikuiti as of yet. Got a good deal on a Lilli and it should be arriving in about 5-7 days. IF that stuff works as well as they say it will and the AR material cuts the glare then maybe we dont need as big of CCFL in back. I mean it all depends on cost and ease of the install/mod. Well keep up the good work guys. Youre way ahead of me at this point.
    If you need a research monkey ill be following this thread and try to supply you with whatever info comes my way
  3. #143
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Jerry, found a very nice looking inverter supplier. gonna contact them for specs and prices. They have ones that can provide the noce high startup voltage and have PWM and voltage dimmer controls. I am not sure how the Xenarc dimmer works - could be pwm or voltage based but i think a standalone version would be better anyway with a dial control AND a reactive system. A PWM system should be pretty easy to build and more reliable than a voltage controlled system.
    This place i have found supplies most laptop makers so should be pretty good.
    do you think the 5 pass is too much? I think we are aiming a bit too high and will block some of the reflected light with too much tube. I am bit worried about inverter noise and heat.
  4. #144
    Mar 2004
    Bristol
    I wonder what happened to the guy who made this thread! he has disappeared!
    oops, we kind of thread-jacked him! But in a good way.
  5. #145
    May 2003
    Miami, FL
    Quote Originally Posted by Scouse Monkey
    awesome, let me know on what you find out.
    well we still dont know if they will give us the bends we need, so might end up with 3 pass or 2 pass. i'm just waiting for the drawings back from them to find out. But I think the sheer length of the tube and the surface area we are dealing with will make up for the the loss of reflection against the back.
    肚子笑痛了
    S60 Install
  6. #146
    May 2003
    Miami, FL
    I will post a status update as soon as I get the specs back
    肚子笑痛了
    S60 Install
  7. #147
    Mar 2004
    Bristol
    Urgent Request
    Does anyone have the data sheets for the LCD panels in the Xenarc and Lilliput screens?
    We are particularly looking for the Chromaticity data i.e. the x and y CIE chart data (I am expecting it to be in the range of 0.3-0.33 for both).
    These are the panels I believe are in the two monitors:
    Xenarc screen - Panasonic EDTCB18QEF LCD Panel
    Lilliput screen - Hitachi TX18D11VM1CAA LCD Panel
  8. #148
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    well i tried - ive been googling my títs off for over half an hour and havnt found anything that looks like CIE data for the hitachi
  9. #149
    Mar 2004
    Bristol
    Quote Originally Posted by Mad Ad
    same here!!! found some bloody awesome sites for LCDs, inverters and touchscreens though. Found a proximity TS film that works behind 1" of glass or even double glazing! bad news is it's £450 for a 15" screen
  10. #150
    Mar 2005
    kansas
    may have just found the hitachi data sheet. Still no luck on the pannasonic though. Found a couple places that have data sheets hanging out there *** but they want to charge for there service. DICKS. oh well if the hitachi pans out i will let you know
  1. Xenarc 7" LCD, but no touchscreen
    By celicagtsblak in forum LCD/Display
    Last Post: 09-27-2004, 11:27 AM
  2. FS: 15inch LCD and touchscreen
    By CURTISBEEF in forum Classified Archive
    Last Post: 09-25-2004, 01:46 PM
  3. cheap lcd + touchscreen options?
    By dunks in forum LCD/Display
    Last Post: 05-25-2004, 10:05 PM
  4. WTB: 7" - 8.4" LCD touchscreen
    By robiewp in forum Classified Archive
    Last Post: 05-25-2004, 09:36 PM
  5. can you give me LCD shop on internet..?
    By helloman in forum General Hardware Discussion
    Last Post: 02-03-2004, 11:44 AM
