Page 22 of 29 FirstFirst ... 121314151617181920212223242526272829 LastLast
Results 211 to 220 of 282
Thread: So, give us new LCD touchscreen options!
  1. #211
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Cheers geezer. Much lower than expected. We could do with the current too as that is what kills CCFLs if it is too high!
  2. #212
    Mar 2005
    kansas
    i finally found the peice of ****
    TX18D11VM1CAA data sheet. This is the absolute best i can do. Unfortunately i dont think it has the CIE info on it
  3. #213
    Mar 2004
    Bristol
    cheers geezer. shame there is no CIE stuff but JCDs order the tubes now so fingers crossed!
    400nit from a side mounted CCFL
    wonder what our design will look like!
  4. #214
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Allright everyone, another status update. It turns out the place in china also has the exact inverters we need to power the tubes, I have added some to that order. So now we wait for the tubes!
    肚子笑痛了
    S60 Install
  5. #215
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    Brilliant work guys!! I knew of your efforts from my time whoring in OT, but now that I've finally read this thread I am really impressed. Keep up the good work. And if you need a beta tester.........
  6. #216
    May 2003
    Miami, FL
    Well depending if this works, I will be selling the extra parts that I dont use, to try to offset the high cost of getting the samples in.
    肚子笑痛了
    S60 Install
  7. #217
    Mar 2005
    kansas
    i figured no one needed that damn data sheet anymore. But it ****ed me off not being able to find it. And if i get ****ed at something it either gets smashed or i make it work one way or the other. So i just couldnt stop looking till i found that damn thing
  8. #218
    May 2003
    Miami, FL
    hey they still are helpful for reference, i've put them away somewhere safe for a rainy day.
    肚子笑痛了
    S60 Install
  9. #219
    May 2003
    Miami, FL
    Status update, I wired the money today. So they are saying 3 days to make the tubes and 3 days in-transit. So maybe by week after next we'll be able to start testing!
    肚子笑痛了
    S60 Install
  10. #220
    Oct 2004
    NY
    hey guys, I've been doing pretty much the same research & have come to similar ideas as you guys have here in this thread.... I have a 12.1" widescreen that I am using from a laptop & I have dissasembled it & am going to be able to have the whole rear of the lcd exposed to my light source...I have built a stainless steel "pan" type box that the lcd will sit on & I have built it to be 2 1/2" deep.....up until I read this thread I was considering either multiple cold cathodes or I was thinking of putting an aray of 150-200 high bright led's (20,000-26,000 each).......this thread however showed me the led array that was made to be a backlight for an lcd & I see that they don't use just white....I saw that they are using white in combination with other colors....& some sort of control for white balance....these are things I haven't considered as far as color tempature is concerned. this is having me reconsider the led approach altogeather.....
    I have played around with lcd's for a while.....I even set one up with a xenon bulb as a backlight....it was supper brite but ran way too hot....I was afraid the lcd would melt....it also wasn't dimmable...which is a definate requirement to my new install. My question to you guys is that if I decided to go with several cold cathodes what would be my best option as far as powering & dimming......I think the ultimate would be with a light sensor auto of course, but would settle for just a pot type adjustment that I could have a knob to control briteness, I wouldn't want to have to have several pots on several power supplies though...any ideas?
    also, just a note, i picked up a sheet of 3m's vituiluki anti glare film at my local micro center...it was packaged as an add on anti- glare screen for lcd.....it was made for a 15" lcd & cost $42.99 but is trimmable to size....I tried it in the car & it defanately makes a difference.....with my liliput totally washed out from the sun I slipped this in place over it & it was defanatly readable when it wasn't without it! if anyone is interested in this I will check the packaging & give you #'s off the package, or any other info I see that may help you locate one....it was packaged by 3m & appeared to be a readily available item...I have seen it in that store for a while, but thought that was a lot of money for a thin piece of translucent plexi untill I started doing research on lcd's & learned all about 3m's vituluki concepts....when I saw this vituluki on the package I just knew I had to play with it.......
  1. Xenarc 7" LCD, but no touchscreen
    By celicagtsblak in forum LCD/Display
    Last Post: 09-27-2004, 10:27 AM
  2. FS: 15inch LCD and touchscreen
    By CURTISBEEF in forum Classified Archive
    Last Post: 09-25-2004, 12:46 PM
  3. cheap lcd + touchscreen options?
    By dunks in forum LCD/Display
    Last Post: 05-25-2004, 09:05 PM
  4. WTB: 7" - 8.4" LCD touchscreen
    By robiewp in forum Classified Archive
    Last Post: 05-25-2004, 08:36 PM
  5. can you give me LCD shop on internet..?
    By helloman in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:44 AM
