Page 4 of 29 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 282
Thread: So, give us new LCD touchscreen options!
  1. #31
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by jtp
    Think people. Just because an LED uses 20ma doesn't mean you add them all up to get the total current. On a 12V system, you can put 3 to 4 of these in series without resistors. And guess what, only 20ma is running through the line. Bright LEDs work between 3 & 4 volts, not 12 or 14V.
    We know bright white LEDs run at 4V thank you!
    and we know how to design an LED array.
  2. #32
    Mar 2004
    Bristol
    No monkey:
    In his scenario, it would really only be about .5 - .7 amps in a car.
    ahh i didnt realise you were checking JCs calcs. yeah he is out as he hasnt considered the 12V being split between 3 LEDS reducing the 2A to 2A/3= 0.6-0.7A. So 10W which is about right. But he would need about 200 LEDs so that would be about 1.5A. But thats no porblem at all.
    200 LEDS at 30cents would still be $60!!!! But you could easily dim them or just light some.
    If you used them in conjunction with the existing CCFL (ir is a perimeter one) it could be easy...
    However i think the CCFL route is an easier option it just depends how much light they give out.
    Next post i will go through my calcs (just didnt want a big post)
    EDIT: and don't call me Monkey!!!
  3. #33
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    doh! I knew that didnt sound right
    Well the backlight inverter is going to have to be more powerful in order to drive that bigger tube, so I already have a ccfl inverter that provides dimming support. So I think I am just going to pull the wrap around tube and pull the plexiglass transmitter, so that just leaves the diffuser material.
    but I probably will try it both ways.
    肚子笑痛了
    S60 Install
  4. #34
    May 2003
    Miami, FL
    Allright well I sent them a e-mail, i'm going to check my digikey catalog when I get home to see what they have.
    肚子笑痛了
    S60 Install
  5. #35
    Mar 2004
    Bristol
    I've been calling you monkey for the last month.
    ??? where????
  6. #36
    Feb 2005
    Oklahoma
    I would be interested in going in on the group order if it helps make the lilliput way birghter.
  7. #37
    Mar 2004
    Bristol
    Quote Originally Posted by jcdillin
    cool, let me know how it goes.
    these were the LEDs i was thinking off..http://www.luxeonstar.com/
    6 of these bad boys and you would be laughing! but they need cooling!
  8. #38
    May 2003
    Miami, FL
    hrm, sounds like a projecter in my car
    肚子笑痛了
    S60 Install
  9. #39
    May 2003
    Miami, FL
    Quote Originally Posted by Scouse Monkey
    $42 for each of these buggers
    $252 for a backlight....hrm..
    but they are 120 lumens each
    and having 5w LED's in your car.....priceless
    肚子笑痛了
    S60 Install
  10. #40
    May 2003
    Miami, FL
    well I might pick up 2 of these they are pretty cheap and will at least give me an idea of how big of a box I have to build behind the lcd and to see if I can get the light even enough
    肚子笑痛了
    S60 Install
  1. Xenarc 7" LCD, but no touchscreen
    By celicagtsblak in forum LCD/Display
    Last Post: 09-27-2004, 11:27 AM
  2. FS: 15inch LCD and touchscreen
    By CURTISBEEF in forum Classified Archive
    Last Post: 09-25-2004, 01:46 PM
  3. cheap lcd + touchscreen options?
    By dunks in forum LCD/Display
    Last Post: 05-25-2004, 10:05 PM
  4. WTB: 7" - 8.4" LCD touchscreen
    By robiewp in forum Classified Archive
    Last Post: 05-25-2004, 09:36 PM
  5. can you give me LCD shop on internet..?
    By helloman in forum General Hardware Discussion
    Last Post: 02-03-2004, 11:44 AM
