look at this bad boy, 24.57 watts 567 lumens
http://rocky.digikey.com/WebLib/Lami...-32D0-0133.pdf
:cough: $158.18 each![]()
yeah thats what i was loking at in work today. 7euros each from germany. found em in the UK for £8 at Radio Spares but i am sure i can get them for half that somwhere.Originally Posted by jcdillin
They do 1W and 3W but i am concerend about the heat dissipation.
But you don't need an inverter which is good.
I was thinking 8 of the buggers in this pattern:
X---X---X
--X---X--
X---X---X
and a diffuser. But at 110-140 deg angles they should be pretty well diffused anyway going on the Lambertain intesisty graphs for the high dome lens.
EDIT: ahh i jsut found the 5W ones for £21!!! it says they are 120lumens but the 1W is only 18lumens - not sure how that works!!!
3W is £8 and gives 80 lumens - that seems a better price/performance ratio and using more is better for diffusion and the 3w is easier to cool.
肚子笑痛了
S60 Install
look at these: i was wondering about doing all the colours to make white so it can be trimmed and they do it already...http://www.luxeonstar.com/sub_catego...k_str=189::195
that is interesting, man those things are pricey
肚子笑痛了
S60 Install
yeah i saw something by Osram like that but smaller. how does lumens relate to cd/m2???Originally Posted by jcdillin
might help: http://www.theledlight.com/lumens.html
I was just looking up the same thing
肚子笑痛了
S60 Install
I wonder if I could squeeze by with 140mm CCFL's
I found some that are 38000 cd/m2 for $10.29 each, much easier to afford there.
肚子笑痛了
S60 Install
yeah but they need an inverter and what is their area provinding 38000cd/m2? got a link to them?Originally Posted by jcdillin
did you say you had a quote for the heater element style CCFL from that other site?
