Page 1 of 29 1234567891011 ... LastLast
Results 1 to 10 of 282
Thread: So, give us new LCD touchscreen options!
    Nov 2004
    Ok, I have finally tweeked my carPC and it is exactly how I want it. It works every time, ALL the time... and for those of you who have built these things know that is a feat
    But my stupid Lilliput has that 'ghost image' problem as well as syncing with the display so every 3 out-of 10 times it comes up blank. How frustrating to have the LCD be the problem in your design!!! Plus, don't even get me started on the brightness!
    So who has info on when/if a new HIGH BRIGHTNESS 7" touchscreen will be coming out?!?
    There has to be something on the horizon, right!?!?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    i'm looking!!! I found some 300cd/m2 but with that reflective technolgy to make them go brighter in daylight and a 5wire TS (bettert than 4 wire) but they cost £500! ($900) so i doubt you would want to payt hat much!
    if anyone has a smached Xenard take the LCD apart and post lots of high res pictures - maybe we can design a new LED backlight system.
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Quote Originally Posted by davem
    From what owners say around here 7"s have non-standard (for video cards) resolution. So, if a new one comes out, it would be wonderful to have one with more standard resolution
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    i'm already working on a upgrading my lilliput brightness
    right now i'm just trying more ccfl's but next i'm going to try ultrabright LEDs
    肚子笑痛了
    S60 Install
    Mar 2004
    Bristol
    Quote Originally Posted by jcdillin
    PICS PLEASE!
    I have an electronics clean room at work i am eyeing up for doing some kind of brightness mod in!
    Mar 2004
    Bristol
    Quote Originally Posted by joshthepilot
    One bonus to the hitachi screen (lilliput) is that you can seperate it from the backlight module and the only pcb is that little square corner piece. So if you create a brighter backlight, it is very easy to mount. The panasonic screens have a much larger pcb to have to work with and avoid breaking.
    Josh, do you have any exploded pics/diagrams of the panasonic and hitachi LCDs you could send me?
    May 2003
    Miami, FL
    I can take some more if you want scouse
    this is the lilliput raw panel
    and the diffusers I pulled from a bigger LCD
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    yeah on the hitachi screen, the panel comes off the backlight module
    肚子笑痛了
    S60 Install
    Mar 2005
    kansas
    Has anyone tried to use electroluminescant material as a backlight for an LCD? I was on a website the other day that sells it in sheets big enough to do a 10 in screen. I was thinking it might give off more light than just a few LED's.
    May 2003
    Miami, FL
    I have a sheet of it, and it's not bright enough at all
    肚子笑痛了
    S60 Install
  1. Xenarc 7" LCD, but no touchscreen
    By celicagtsblak in forum LCD/Display
    Last Post: 09-27-2004, 10:27 AM
  2. FS: 15inch LCD and touchscreen
    By CURTISBEEF in forum Classified Archive
    Last Post: 09-25-2004, 12:46 PM
  3. cheap lcd + touchscreen options?
    By dunks in forum LCD/Display
    Last Post: 05-25-2004, 09:05 PM
  4. WTB: 7" - 8.4" LCD touchscreen
    By robiewp in forum Classified Archive
    Last Post: 05-25-2004, 08:36 PM
  5. can you give me LCD shop on internet..?
    By helloman in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:44 AM
