Results 1 to 9 of 9
Thread: Lilliput 7" not working properly
    R@b
    R@b is offline
    Oct 2004
    Netherlands
    I've had it with this piece of ****. I haven't been able to use it for one slight moment.
    When I am booting 9 out of 10 times it isn't showing anything. When I get in Windows and I power on the Lilliput it gives me the screen for about 1 minute (less most of the times). Then everything is fading and I don't see anything anymore.
    I just want it to run in 800x600 75hz appareantly nothing is working. Is this piece of junk malfunctioning and should be send back to the distributor. Or am I being stupid and should I consider different settings?
    Please enlighten me, thanks!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    i'm running mine at 800x600 @ 75hz with no problems, have you tried 60hz?
    how are you powering the screen?
    how long are your video cables?
    what video card are you using?
    肚子笑痛了
    S60 Install
    Apr 2005
    I have a Lilliput screen as well and noticed some of the behavior you describe. Specifically, my screen doesn't come on (or rather displays a very faded "Jurassic Park" image) until Windows XP gets to the boot screen. Once the boot screen appears, everything is just fine.
    I don't see this behavior under Windows 2000 for some reason. It doesn't bother me much to wait until the Windows XP login screen, so I really haven't looked into it much.
    R@b
    R@b is offline
    Oct 2004
    Netherlands
    I am using all the standard cables that comes with the screen. I do not have any modified/special cables.
    I've tried running it in 60hz doesn't do anything either. The pc is using the reg. onboard videocard from EPIA M10000. I've just hooked the little headache to my normal pc (800*600 75hz) same drama.
    R@b
    R@b is offline
    Oct 2004
    Netherlands
    Quote Originally Posted by White Night
    Even if it didn't show up the whole booting sequence, I wouldn't mind. Just the problem is it's not doing anything while in Windows after a small time period (i.e. 1 min).
    May 2003
    Miami, FL
    sounds like you need to get a RMA then.
    肚子笑痛了
    S60 Install
    R@b
    R@b is offline
    Oct 2004
    Netherlands
    Quote Originally Posted by jcdillin
    Yeah jcdillin I am going to call the reseller first thing tomorrow.
    How does it work for you when your in Windows? Can you use it hour after hour without any problem? Watch movies etc?
    May 2003
    Miami, FL
    I took a road trip from south florida to north carolina, 12 hours straight, never even had a hiccup
    肚子笑痛了
    S60 Install
    R@b
    R@b is offline
    Oct 2004
    Netherlands
    Sounds like the kind of screen I am wanting to get
  1. Rca on Lilliput not working
    By blustreak in forum LCD/Display
    Last Post: 04-06-2005, 07:05 PM
  2. Replies: 3
    Last Post: 10-04-2004, 06:13 PM
  3. FS: 7" Lilliput w/ TS and CNX-P1260
    By brandon in forum Classified Archive
    Last Post: 09-19-2004, 11:39 PM
  4. FS: 7" Lilliput Touchscreen VGA Monitor : Broken
    By jaeger in forum Classified Archive
    Last Post: 08-21-2004, 08:46 AM
  5. Lilliput not working v1 & v2
    By darthvinh in forum LCD/Display
    Last Post: 05-08-2004, 04:37 AM
