try running a common ground. Run a cable from your comp (and any other equip that is feeding the xenarc with vid), to the xenarc, then to the ground. Also, make sure your grounds aren't ran too far. For this i would use a 10 or 8 awg since you are also gonna use it to ground your carpc and you will prolly get some line drop. If the carpc and the xenarc are too far apart. Just run one cable from the pc to a gound point (not too far from the xenarc or comp). and run a cable from the xenarc to the same ground point. I had the same problem and this fixed it for me. Also make sure you keep your signal and power wires as far away as possible
LinkBack URL
About LinkBacks
