+ Reply to Thread
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Powering your LCD Monitor
  1. #21
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    The M1-ATX 90W power supply works great with the Xenarc 700TSV. I have my Xenarc running directly off the 12V line from the PSU with no problems. There is no flickering and the picture is clean and stable.
    Civiputer: Dont have one anymore, but here is what is used to be!
  2. #22
    May 2006
    Calgary, Alberta
    Quote Originally Posted by mbkowns
    I decided to be cheap on the wire for my Xenarc. Instead of buying a new cable I just cut the cig adapater one. If I need the adapter again which I won't I will resplice it back together. Anyway
    Ground on the wire is the outer strand and the positive is the white wire.
    I have this hooked up to a OPUS POL
    Which wires do they go to on the molex? I got a red, 2 blacks and a yellow. I don't have a voltmeter.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #23
    Elsewhere
    Quote Originally Posted by Maheriano
    Red = +5v
    Black = Ground
    Yellow = +12v
    You don't need a voltmeter to determine that, just a simple trip to the search tool or Google.
    How about the Wiki?
  4. #24
    May 2006
    Calgary, Alberta
    Rodger.
    Yellow and black. Now I just have to put a 6 foot piece of wire between them.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  5. #25
    Newbie balconio's Avatar
    Jul 2006
    Rochester, NY
    Nothing new here, just saying that powering the screen off a Molex or such is pretty sweet. I've got a p4 ready psu running a duron processor so I tapped into the 4wire p4 connector, now I've got auto on/off for the screen.
  6. #26
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    hi... im going to be installing a car-pc.. and a touchscreen liliput monitor...
    (wen i get the cash lol)
    say i wanted to run the screen of the power supply... but wanted to use the screen for xbox.. ps2 dvd player ect.. ect... i would have to leave pc on.. ??? or would the powersupply still pump out 12v wen pc is off??
  7. #27
    Low Bitrate NoTicketsPlease's Avatar
    Jan 2006
    San Diego, CA
    Quote Originally Posted by 306
    The pc would have to be on. You could just switch to the cigarette lighter power adaptor when needed. If the power plug on your lilli wont be accessible you could maybe wire a switch so you could alternate between the two - pc power or power from cigarette lighter.
    Windows XP is ****!!!
    AMD Sempron 3000+, ASRockVM800, 256MB, 250GB 3.5", DVDRW+, WIFIg, m2-atx, Lilliput 8", RR, GoogleEarth
    Need: daylight viewable screen!
  8. #28
    306
    306 is offline
    Newbie 306's Avatar
    Jul 2006
    Blaenavon
    Yea i know that ... but doesnt that defete the object of havin it on the pc power suply.. becoz of voltage drops.. wen cranking
    Head unit - Pioneer - DEH-P6400R
    Speakers - componant sets up front, 2x mutant 2way in rear.
    Amps - 2x 500w
    Subs - 2x 12" 500w 50oz
    90% dun.. need screen :~
  9. #29
    Jan 2006
    San Diego, CA
    I have mine on my pc power mostly so it turns on automatically when the pc boots. Its also a good steady current but you can run your screen off of the cig lighter just fine even during crank AFAIK. Surviving crank is a pc issue not a screen issue.
  10. #30
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Another suggestion when powering your screen off the PC PSU like this is to use a relay to switch the power and use the ign/acc on the dash to activate the relay. Then your screen will be off as soon as you get out of the car and not stay on while the PC is shutting down and obviously attracting attention.
+ Reply to Thread
  1. FS: 10.4" LCD monitor with TV tuner
    By CDesigns in forum Classified Archive
    Last Post: 02-13-2004, 10:04 AM
