Results 1 to 8 of 8
Thread: Lilliput guru's needed
    Constant Bitrate bulgogi777's Avatar
    Jun 2004
    NW FL
    ok, I just redid my lcd install, and now I've got a funky display problem as you can see in the photo:
    Is there any way I can fix this? or am I screwed
    Please help~! Thanx~!
    90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
    My Install
    Jun 2004
    NW FL
    oh, and I tested my carputer with a regular monitor to make sure it wasn't the carputer itself...
    My Install
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    the 40 pin ribbon from the controller to the lcd is probably loose, at least thats what mine looked like when it was
    肚子笑痛了
    S60 Install
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    also make sure the pins on the 9pin din connector aren't bent, I've had that problem before
    Jun 2004
    NW FL
    cool, i'll check it out, and report back, thanx for the fast responses
    My Install
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    if those don't work try it with a different vga cable as well.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    its the 40 pin ribbon cable
    Newbie Darth's Avatar
    Jan 2005
    CY
    Have you taken the TFT apart? If not then it's not the 40pin ribbon.
    I had the same or worse problem and I had to remove the 9pin connector and solder the wires directly. You are missing the "Green" color, you have only Red and Blue.
    For the first step try and reconnect the 9pin connector, move it about and if your lucky it will be ok. Otherwise you have to solder the wires and bypass the 9pin connector.
    Do not underestimate the power of the Dark Side !
  1. Lilliput 7" Cable help needed. (Bad 9pin DIN)
    By FireAnt in forum LCD/Display
    Last Post: 01-07-2011, 12:50 PM
  2. Help needed from EE gurus - 5 channel A/B switch
    By Dr. Jeff in forum Hardware Development
    Last Post: 02-17-2005, 09:10 PM
  3. Lilliput Power source needed
    By R3l0ad in forum LCD/Display
    Last Post: 01-10-2004, 10:28 AM
  4. electronic Guru's needed ...
    By felix99 in forum Power Supplies
    Last Post: 11-21-2002, 10:46 AM
  5. guru's help needed! (atx)
    By embedded in forum Power Supplies
    Last Post: 05-11-2001, 08:33 AM
