Results 1 to 5 of 5
Thread: LCD Video cable length?
    Jan 2005
    North Dakota
    Is there a limit to the length of a monitor cable the one from the puter to the display. I put in a 10' extension so i could relocate pc to trunk.. Monitor says no signal... I hooked up a house monitor with normal cable and it works fine.... everything for touch screen worked fine till i put in the extension... I've checked all connectors from lcd to puter and they are tight.... If i hook lcd up direct with no other cable it works too... I have 2 extensions totaling 15' between dash and puter... only thing i can think is cable... I'm stumped
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    That's odd. I've got a 15' extension cable that works fine...could be the cable isn't very high quality and the signal levels are degrading too much for one monitor? Don't know, all I can do is fling out wild guesses...
    Constant Bitrate hanzacra's Avatar
    Mar 2004
    Washington, DC
    Quote Originally Posted by LOstBoy
    Did you try hooking up the house monitor with all of the extensions in place? If that worked, I'd double check the extension connections or buy a single extension rather than stringing things together. I have a 10' triple-shielded monitor extension cable and it's never had any problems.
    EPIA M10K, Lilliput 7", 512MB RAM, 40GB 2.5" HD, M1-ATX, RoadRunner, FreeDrive, BU-353 GPS, Sabrent TV Tuner
    Jan 2005
    North Dakota
    I found a video signal booster in town so im gonna try that tonight if not ill have to puzzle some more.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Why two extensions? Keep the install as simple as possible. With two extensions, you have twice the likelihood that either a cable doesn't work or that the signal voltage drops too far to work properly.
    I'd advise what hanzacra said, try the known, good house monitor with the extensions in place. See if that's the problem.
    I'd also advise going with just a single longer extension, rather than two.
    I've got 16 feet on my monitor with no ill effects.
    Want to:
  1. Extending your laptop's LCD cable: FAQ
    By Yuriy in forum LCD/Display
    Last Post: 11-25-2008, 03:06 PM
  2. 7" Roof Mounted Video LCD
    By MP3_TJ in forum Classified Archive
    Last Post: 02-14-2005, 03:55 PM
  3. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
  4. Extending LCD cable
    By CoyoteBoy in forum LCD/Display
    Last Post: 05-27-2004, 01:32 AM
  5. Kiosk parts, Ram, 12.1 LCD, 8mm Video recorder
    By CDesigns in forum Classified Archive
    Last Post: 05-25-2004, 02:27 PM
