Results 1 to 4 of 4
Thread: Newbie: Please help on Hacking a TFT display from laptop.
    Apr 2005
    Question Newbie: Please help on Hacking a TFT display from laptop.
    Hi,
    First of all, my apologies for not being able to figure this all by myself I'm a software engineer, so while I do have some basic electronic skills and theory, it's the first time I try to hack around with electronic parts... which means: completely NOOB
    I've saved form the trash a Toshiba Satelitte S1700-500. The computer doesn't get power from the battery (only from AC). I've tried a new battery and it's the same, so I assume there's something wrong with the power controller. Also, even when plugged, it doesn't stay on for too long (between 10seconds and 5 minutes). The hard-disk is also broken, so I thought about trying to hack around the LCD and figure how to use it as a VGA secondary display.
    After unmouting the LCD off, I've found it's a 13.3" Unipac display, PK070008900 Rev 1.0 with an TAD561 lcd inverter... It seems to be working 100% OK.
    From what I've read in this forums I need a VGA controller. Problem is: where can I find one that is compatible with this display? Also, couldn't I borrow it from the laptop? Or is it possible that the controller is integrated within the motherboard?
    If anyone can help me here, by giving me links, tips, ideas, anything, I would very much appreciate!!
    Thanks in advance,
    Hugo Jose Ferreira
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    Its not really worth the time or MONEY involved.
    Its far easier and cheaper to go get a ready made screen, with a built in power supply. Im not good go into the specifics of it all, but not worth the head ache.
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    If the laptop is more or less complete i'll buy it from you for $40 i have a similar model that needs a few cosmetic pieces, and a keyboard
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Bytter
    If you have read that you need a controller then you chould have also read that the questions always end up being answered in the same way as pate60 has.
    It's really not worth it. + if you want a TS then you will have to fork out for a separate TS controller and overlay which will add a lot.
  1. Toshiba TFT Display
    By RedDragon2kx in forum LCD/Display
    Last Post: 04-20-2005, 10:00 AM
  2. For trade: brand new 15" TFT LCD monitor...looking for used laptop
    By debennett2 in forum Classified Archive
    Last Post: 04-08-2004, 10:51 PM
  3. Please help a newbie choose a display...
    By prerunnerv6 in forum LCD/Display
    Last Post: 09-14-2002, 03:15 AM
  4. Newbie q': looking for in-dash TFT
    By Lithy in forum LCD/Display
    Last Post: 06-22-2001, 06:30 PM
  5. newbie question..laptop screens
    By InAFocus in forum General Hardware Discussion
    Last Post: 08-23-2000, 11:15 PM
