yeah through the shuttle PSU would be nice and regualted. Should avoid any spikes and stuff. use the yellow and adjacent black wire on a molex connector (get a Y if you dont have enough). It draws 1A max.
I have a shuttle that is powered with the stock PSU through an inverter. Would it be okay to power my Xenarc through the carputer or would i be better off powering directly through my cd deck's ACC?
would anyone here be able to tell me why there is a buzzing noise coming from the shuttle? Even when it is powered off, i get a buzzing noise. The case is grounded (one wire screwed into the psu, the other into the case). The noise was reduced somewhat when i grounded it, but it is still significantly there. Could it cause problems with the Xenarc?
