Results 1 to 1 of 1
Thread: AVM-P9000R, AVD-W8000, AVIC-90DVD Help
    Dec 2004
    Here is a picture of the lines that's going across my 8" screen when you try to switch to Nav mode. When I had the 6.5 screen it worked fine. This is where I tested it out, when your in the AVM-P9000R part where it shows you the radio stations or tells you if your on multi CD, track #'s etc. Well if you switch to nav it's supposed to show you those items and instead of a solid back part it has black lines where those items are on top of. I think there is a compadibility issue's with the 8000 and the 9000R. Or the cable that I bought the CD-65RGB is not compatible with the 9000R. I dont know any other RGB cables that could work. I've tried the purple wire to the green and still get the lines. If you hook up the 8000 straight to the Nav it works fine, NO lines. Anybody have this problem?
    I called the 1800 number and talked to a pioneer guy and they show that the W8000 not being hooked up to a Navigation Unit. But the CD-65RGB wire should solve that. But if you look at the little paperwork that comes with the RGB wire it shows you that it hooks up to a Nav but it say's USING AVD-W8000 combined with the Navigation system (AVIC-505) that is a freaking old unit. Also the Pioneer person did not have that wire showing that it can be used on the AVD-W8000
    Here is a video also:Click Here
