Thanks for the response,
I ended up tinkering with xvidtune to get a working 800x480 modeline. Strangely enough I got it working with a pixel clock rate that already existed it via_mode.h (40.00 instead of 31.746 or whatever). Here's my modeline if anyone else comes across this problem.
Code:
Modeline "800x480" 40.00 800 848 976 1056 480 637 641 672 -hsync -vsync
I still don't know why I had to use a different modeline, is my xenarc panel different from everyone elses xenarc panel? Additionally, despite getting the panel to go into 800x480@56, I'm terribly unsure if this modeline is actually the right one, or if its doing minor unnoticable damage to the panel everytime i run it this way. Of all the settings i tried in xvidtune I wasnt able to completely eliminate flicker. I tried getting the vrefresh higher, but anything minorly higher than 56 would make it worse, and then eventually go out of range of the panel. What is your refresh rate at when you go into 800x480?
I also don't know the exact horizsync and vrefresh xorg settings for the panel either, xenarcs website only lists the modeline that supposedly works. So for now I just ball park those numbers. Any help/insight you (or anyone else) has/have would be greatly appreciated..
-p
