Results 1 to 6 of 6
Thread: Double-din is closest to 16:9. Should I go with 8" 16:9? Which?
    Raw Wave justintime's Avatar
    Apr 2005
    I'm planning to fit a touchscreen LCD in my car's Double-Din space.
    Dimensions: 7.5"W x 4 3/8"H
    My plan is to remove the LCD's bezel/housing etc, and fit the bare LCD. Even an 8" however would be smaller than the opening, so I might have to bondo/fiberglass or who knows what to cover up and look more factory.
    In any case, these dimensions seem very close to 16:9 screen ratio, and also closer to a 8" diagonal at that.
    I was going to go with a 8" Xenarc TS, but the dimensions of those seems to be 4:3 ratio. Huh?! ANy widescreen 8" Xenarcs? Or other good TS options?
    Thanks!
    Low Bitrate 99bravada's Avatar
    Dec 2003
    Fort Lauderdale
    Quote Originally Posted by justintime
    7" x 4" is double-din standard...
    You sure it's double-din?
    99bravada.
    Current:
    2011 Black Jeep Wrangler Unlimited Rubicon | 20" KMC Rockstars | 35" Nitto Mud Grapplers | Rugged Ridge XHD Front Bumper | Kicker KX350.4 amp
    Apr 2005
    Well, not 100% sure. I did take those measurements myself though, and they are precise.
    My vehicle is a 2002 Honda CR-V, and has a dd 6-disc CD changer factory. They put a Navi there in European / Japanese models.
    Quote Originally Posted by 99bravada
    99bravada.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    lilliputs size is 7x4 around the beveld trim u can do a recessed monitor
    Apr 2005
    Which model?
    Also, I thought I heard consensus that liliis where dimmer?
    Quote Originally Posted by xdjxklusivex
    Dec 2004
    the 7 inch lillis... hmm ioono i saw the comparision on digitalww and i like the lilliput better the colors are richer then the xernac stuff they look yellowish compared to the lilli
  1. Available Double Din Frame?
    By fenderbender in forum Fabrication
    Last Post: 11-20-2008, 10:48 PM
  2. Double Din to Single Din
    By loganm in forum General Hardware Discussion
    Last Post: 03-20-2005, 10:58 PM
  3. double din adaptor? 2 1-din devices in a double din space possible?
    By ucidave in forum General Hardware Discussion
    Last Post: 09-17-2004, 06:10 PM
  4. 8" Lilliput LCD vs. double DIN?
    By hey_allen in forum LCD/Display
    Last Post: 09-02-2004, 10:42 PM
  5. 8" lilliput in a double din?
    By mykolJay in forum LCD/Display
    Last Post: 06-19-2004, 10:07 AM
